MAC cant create maps
- Tetris
- NUMA Profile: http://www.nmaps.net/user/Furikabute
Thx !!
Sincerely,
A fellow Macbook Pro user
- Tetris
ok, once you press the "e" key to start editing, you can press "fn+erase" (or "fn+period") to open the tile editor. You should also be able to press "fn+m" to enter the object editor. To go back, you should be able to press "fn+left arrow" instead of the home key.
Let me know if that works.
- Tetris
- Tetris
- Tetris
- NUMA Profile: http://nmaps.net/user/drayr
http://pqrs.org/macosx/keyremap4macbook/
It's called KeyRemap4Macbook. Once installed (you will have to restart), you will be able to find it as a System Preference pane, and it should also appear in your menu bar. It allows you to remap a certain key (can't remember which one) to Insert. There are a lot of options, so you may have to search for that specific one. Hope this helped.
- Triforce
- On the Psychic Highway
- Ego Lancer
- NUMA Profile: http://nmaps.net/user/fingersonthefrets
egh I've looked through 3 times and I can't see it. This is so frustrating hahaDrayr wrote:Okay, I had the same problem when I first got my Macbook a year or so back. The solution I found lies in this application:
EDIT: I'm using a macbook pro with this keyboard
I think the operating system is 10.5.4. anyone got any solutions?
fn + delete works for tiles, but nothing seems to work for objects (including the ones i've been seeing recommended: fn+., fn+enter, fn+0, fn+m)
- NUMA Profile: http://nmaps.net/user/sayko
- Ego Lancer
gonna try that now, thanks for the tipsayko wrote:Maybe a screen keyboard with PC Keyboard layout?
- NUMA Profile: http://nmaps.net/user/lukesv
- Ego Lancer
Ps. by "gonna try that now" it seems i meant "gonna try that in a while"
within the next day I'd say though
edit: onscreen keyboards for mac either cost (and i'm not sure they have insert function or not), or in the case of the included onscreen one doesn't have insert. bleh.
- Ego Lancer
It would probably work, but the specific macbook pro I have doesn't have a home or help key :/ thanks for the suggestion thoughsayko wrote:I'm not sure if it would solve your problem, but did you try the "Help" key (or Home) in Ned? I've heard that key does same work with Insert key.
- Ego Lancer
Naroquatt wrote:Okay, I had the same problem when I first got my Macbook a year or so back. The solution I found lies in this application:http://pqrs.org/macosx/keyremap4macbook/It's called KeyRemap4Macbook. Once installed (you will have to restart), you will be able to find it as a System Preference pane, and it should also appear in your menu bar. It allows you to remap a certain key (can't remember which one) to Insert. There are a lot of options, so you may have to search for that specific one. Hope this helped.
fingersonthefrets wrote:egh I've looked through 3 times and I can't see it. This is so frustrating haha
When I downloaded it from the site, an orange open box appeared (it's icon) in my downloads folder. I had to click on it and run that box in order to be able to install it, then restart it. Simply downloading that box will not work. Also I didn't have to do the the system preference pane: fn + m worked after installing it. :3Drayr wrote:Okay, I had the same problem when I first got my Macbook a year or so back. The solution I found lies in this application:
i'll try the keyboard remapper linked earlier on
edit: restarted after installing the keyboard remapper and fn+m works for objects now :3
- Tetris
I sort of left out some steps :P but it works, doesn't it?im_bad_at_n wrote:When I downloaded it from the site, an orange open box appeared (it's icon) in my downloads folder. I had to click on it and run that box in order to be able to install it, then restart it. Simply downloading that box will not work. Also I didn't have to do the the system preference pane: fn + m worked after installing it. :3Drayr wrote:Okay, I had the same problem when I first got my Macbook a year or so back. The solution I found lies in this application:
