The Highscore Rankings
A little bit early for that now (or late, by about a week and a half), but it sure was spectacular.999_Springs wrote:Brilliant. Run of the year, maybe?
I believe van innovated thatska wrote:TFK innovated 81-2 which allowed me to easily nab my Top-20 back on that level bringing me back to the 270's.
Sorry for the mis-credit. Does anyone know approximately how many frames faster van's route is? It certainly makes it much easier to obtain a top-20. It also must be noted that there are some opportunities for corner jumps.ToeFaceKiller wrote:Yeah, that's vans route for sure.
Which corners??ska wrote:It also must be noted that there are some opportunities for corner jumps.
I dont know if ska is thinking in this one, but when I saw your run I thought of this one:ToeFaceKiller wrote:I'm not sure how much faster it is than the other route (or if it even is!?), but I know at least 2 more frames could be squeezed out of this one.Which corners??ska wrote:It also must be noted that there are some opportunities for corner jumps.
I dont know if its possible, but I cant try it, its too difficult.
You could also do a corner kick at the second rightside platform, like in xelas old demo (this one in the 3rd rightside platform), but I dont know if it worths the try, its too dificult and you dont win that much time.
yeah, the diagram was one such corner, plus others earlier; I also found a variation on the top part that nets about the same score as current 0th (btw 4 way tie, I can't remember the last time that happened!). The variation is that instead of jumping for the exit switch; just keep running right and don't pull back on the fall. You just run off the little lip and with enough momentum you dash up the slope, do a perp jump, nab the switch as high as possible then jump as soon as you land; you can't afford to lose any speed on impact. I hope that made sense, i can draw a pic if needed.EddyMataGallos wrote:I dont know if ska is thinking in this one, but when I saw your run I thought of this one:ToeFaceKiller wrote:I'm not sure how much faster it is than the other route (or if it even is!?), but I know at least 2 more frames could be squeezed out of this one.Which corners??ska wrote:It also must be noted that there are some opportunities for corner jumps.
Yeah I understand you ;Dska wrote:yeah, the diagram was one such corner, plus others earlier; I also found a variation on the top part that nets about the same score as current 0th (btw 4 way tie, I can't remember the last time that happened!). The variation is that instead of jumping for the exit switch; just keep running right and don't pull back on the fall. You just run off the little lip and with enough momentum you dash up the slope, do a perp jump, nab the switch as high as possible then jump as soon as you land; you can't afford to lose any speed on impact. I hope that made sense, i can draw a pic if needed.
I also thought of another route, its the same route as the current one, but the inverse, i mean:
I can get a picture now, i'll post it here asap.
This way you dont have to jump after the wj because you get the switch while on the wj.
Maybe faster if well done, but im not sure.
This is before:
But the problem is that the wj isnt enough to get to the end of the left platform, so you have to keep running a bit, to get the gold, and that makes you lose some of the gained time.
I think your route would be better if well done, i've tried, but I cant do it well.
That's fine, school comes first (in some cases that's not true, hehe)TheRealOne wrote:Well I fucked up again it's Tuesday and I haven't posted the rankings. I can maybe later today if I have some time, but it is final week at school and I have little to no time. So if someone else could post the rankings that would be helpful. I will try and get it done, but I might not have time until tomorrow afternoon.
I don't think I could do the rankings, I dunno where to add / subtract 0th's to people. Plain nhigh file won't do the job I guess.
- As of 12/14/10
- Includes Tied 0ths
04-4 - Old: [xaelar, 143.800] New: [vankusss, 144.000] => [xaelar, 144.025] => [xaelar, 144.075]
05-4 - Old: [xaelar, 126.200] New: [vankusss, 127.025]
08-2 - Old: [xaelar, 186.375] New: [vankusss, 188.100] => [xaelar, 188.350]
08-3 - Old: [xaelar, 202.275] New: [vankusss, 202.575] => [xaelar, 202.600]
09-1 - Old: [xaelar, 157.825] New: [vankusss, 158.125] => [xaelar, 158.275]
12-4 - Old: [xaelar, 231.775] New: [ToeFaceKiller, 232.075] => [ToeFaceKiller, 232.525]
17-1 - Old: [xaelar, 142.350] New: [vankusss, 142.375]
18-3 - Old: [Darkshadow1416, 127.400] New: [lookatthis, 127.425]
27-1 - Old: [xaelar, 100.100] New: [lookatthis, 100.725] (he beat roadrage)
34-0 - Old: [xaelar, 117.575] New: [vankusss, 117.625]
35-1 - Old: [xaelar, 128.325] New: [vankusss, 128.350]
35-2 - Old: [xaelar, 118.000] New: [vankusss, 118.250]
81-1 - Old: [xaelar, 99.625] New: [vankusss, 100.075]
81-2 - Old: [xaelar, 132.075] New: [ToeFaceKiller, 132.100]
81-3 - Old: [xaelar, 116.125] New: [vankusss, 116.825]
0 xaelar - 204
1 vankusss - 129
2 eru_bahagon - 76
3 Mr_Lim - 63
4 lookatthis - 20
- golfkid - 20
6 Izzy - 17
- Ben_Schultz_11 - 17
8 Seifer - 15
9 macrohenry - 10
10 Hendor - 8
11 Analu - 7
- Kool-aid - 7
13 clux - 6
14 ToeFaceKiller - 5
- Darkshadow1416 - 5
16 johnny_faneca - 4
- The_TGM_Project - 4
- Meta_Ing - 4
19 trib4lmaniac - 3
- glib_jase - 3
0 xaelar - 191
1 vankusss - 121
2 Mr_Lim - 54
3 eru_bahagon - 21
4 lookatthis - 17
- Izzy - 17
7 Seifer - 15
8 golfkid - 13
9 macrohenry - 10
10 Kool-aid - 7
11 clux - 6
12 ToeFaceKiller - 5
- Hendor - 5
- Analu - 5
- Meta_Ing - 4
19 trib4lmaniac - 3
- glib_jase - 3
0 eru_bahagon - 564
1 lookatthis - 558
2 xaelar - 539
3 Mr_Lim - 512
4 Hendor - 408
5 golfkid - 354
6 glib_jase - 336
7 Analu - 335
8 ToeFaceKiller - 320
9 vankusss - 306
10 johnny_faneca - 284
11 Ben_Schultz_11 - 269
12 Darkshadow1416 - 200
13 EddyMataGallos - 173
14 Chouse - 167
15 Izzy - 156
16 trib4lmaniac - 148
17 macrohenry - 139
18 zapkt - 123
19 jg9000 - 115
Seconds - 71775.750
Hours - 19.938
Seconds left until 20 hours - 224.250
Frames left until 20 hours - 8970
08-3 - Old: [xaelar, 202.275] New: [vankusss, 202.500] => [xaelar, 202.525] => [xaelar, 202.550] => [vankusss, 202.575] => [xaelar, 202.600]
Thank you for the rankings, TRO.
I really love how you put this into a story or whatever it is ;D
Yea I feel like Alexander the Great fighting <insert his enemies here>, or Leonidas fighting Xerxes, or Yoda fighting Darth Vader (I watched star wars only once and I don't remember the good guy's name, so I've put Yoda), or Obama fighting Bin Ladin, ... (notice how I am always in the role of the 'good guy', yea that's right)xaelar wrote:I really love how you put this into a story or whatever it is ;D
81-3 was actually like .225 -> .350 -> .825, not that it matters
by nicnac
Well done ;D, but you probably meant to post in the "Post a Run" thread, I believe.natrues peril wrote:1-1 hs, currently 9th and 3 frames off 8th. not really anything special, but its my first noteworthy run within the first 100 levels of the game.
- As of 12/20/10
02-1 - Old: [xaelar, 163.525] New: [vankusss, 163.625]
03-3 - Old: [xaelar, 206.625] New: [vankusss, 206.650]
03-4 - Old: [xaelar, 117.675] New: [vankusss, 117.750]
08-0 - Old: [xaelar, 159.725] New: [vankusss, 159.950]
08-2 - Old: [xaelar, 188.350] New: [vankusss, 188.550]
08 - Old: [eru_bahagon, 542.900] New: [vankusss, 549.550]
16-0 - Old: [xaelar, 101.075] New: [vankusss, 101.175]
16-2 - Old: [xaelar, 111.825] New: [vankusss, 111.850]
28-1 - Old: [xaelar, 121.225] New: [vankusss, 121.275]
29-1 - Old: [xaelar, 133.725] New: [vankusss, 133.900] => [xaelar, 134.375]
29-4 - Old: [golfkid, 121.125] New: [vankusss, 121.450] => [xaelar, 121.525] => [vankusss, 121.575]
86 - Old: [eru_bahagon, 328.100] New: [esp, 331.125]
0 xaelar - 196
1 vankusss - 139
2 eru_bahagon - 73
3 Mr_Lim - 63
4 lookatthis - 20
5 golfkid - 19
6 Izzy - 17
8 Seifer - 15
9 macrohenry - 10
10 Hendor - 8
11 Kool-aid - 7
- Analu - 7
13 clux - 6
- Meta_Ing - 4
19 trib4lmaniac - 3
- glib_jase - 3
0 xaelar - 183
1 vankusss - 130
2 Mr_Lim - 54
3 eru_bahagon - 20
4 lookatthis - 17
- Izzy - 17
7 Seifer - 15
8 golfkid - 12
9 macrohenry - 10
10 Kool-aid - 7
11 clux - 6
- Hendor - 5
- Analu - 5
- Meta_Ing - 4
19 trib4lmaniac - 3
- glib_jase - 3
0 eru_bahagon - 564
1 lookatthis - 558
2 xaelar - 540
3 Mr_Lim - 511
4 Hendor - 408
5 golfkid - 356
6 glib_jase - 337
7 Analu - 334
8 ToeFaceKiller - 319
9 vankusss - 309
11 Ben_Schultz_11 - 273
13 EddyMataGallos - 178
14 Chouse - 166
15 Izzy - 156
16 trib4lmaniac - 147
17 macrohenry - 139
18 zapkt - 122
19 jg9000 - 115
Seconds - 71777.850
Hours - 19.938
Seconds left until 20 hours - 222.150
Frames left until 20 hours - 8886
I also like your wording "in true Raif style".
- As of 12/27/10
02-0 - Old: [xaelar, 118.250] New: [vankusss, 118.600]
05-0 - Old: [Mr_Lim, 193.275] New: [vankusss, 194.225]
28-1 - Old: [vankusss, 121.275] New: [xaelar, 121.300] => [vankusss, 121.475] => [xaelar, 121.575]
50-0 - Old: [vankusss, 164.325] New: [vankusss, 164.400]
50-1 - Old: [xaelar, 181.250] New: [vankusss, 181.550]
50 - Old: [Hendor, 495.750] New: [vankusss, 500.100]
54-3 - Old: [xaelar, 121.975] New: [vankusss, 122.375]
55-3 - Old: [Mr_Lim, 148.675] New: [vankusss, 149.175]
58-4 - Old: [xaelar, 57.550] New: [vankusss, 57.575]
0 xaelar - 193
1 vankusss - 145
2 eru_bahagon - 73
3 Mr_Lim - 61
4 lookatthis - 20
5 golfkid - 19
6 Izzy - 17
8 Seifer - 15
9 macrohenry - 10
10 Kool-aid - 7
- Hendor - 7
- Analu - 7
13 clux - 6
- Meta_Ing - 4
19 trib4lmaniac - 3
- glib_jase - 3
0 xaelar - 180
1 vankusss - 135
2 Mr_Lim - 52
3 eru_bahagon - 20
4 lookatthis - 17
- Izzy - 17
7 Seifer - 15
8 golfkid - 12
9 macrohenry - 10
10 Kool-aid - 7
11 clux - 6
- Hendor - 5
- Analu - 5
- Meta_Ing - 4
19 trib4lmaniac - 3
- glib_jase - 3
0 eru_bahagon - 563
1 lookatthis - 559
2 xaelar - 540
3 Mr_Lim - 511
4 Hendor - 407
5 golfkid - 355
6 glib_jase - 337
7 Analu - 333
8 ToeFaceKiller - 321
9 vankusss - 314
11 Ben_Schultz_11 - 274
13 EddyMataGallos - 180
14 Chouse - 165
15 Izzy - 156
16 trib4lmaniac - 145
17 macrohenry - 139
18 zapkt - 122
19 jg9000 - 115
Seconds - 71780.750
Hours - 19.939
Seconds left until 20 hours - 219.250
Frames left until 20 hours - 8770
I was hoping 54-2 will make it into this week :(TheRealOne wrote:This week van continues his trek towards 0th overall. He comes 1 0th shy of having 3 double digit weeks in a row. .
Thx for the report, though you might want to rename it to "Van's rankings" since nobody else is active.
Damn that is a nice run. I suppose I should have given you some more time I usually post the rankings at night, but I am not changing it now lol. I think we will all know that you got it. :D 10+ 0ths a week for 3 weeks is impressive. Less than 50 0ths left between you and xaelar.vankusss wrote:I was hoping 54-2 will make it into this week :(TheRealOne wrote:This week van continues his trek towards 0th overall. He comes 1 0th shy of having 3 double digit weeks in a row. .
