Old: 215 Frames
New: 192 Frames
I didn't test from the bb double so these may be slightly off, but I bet it is still faster to turn and use the left wall to ws.
I don't think it's usable since you would need to hit the 8-tile in order to be able to slide the left wall, which is too expensive and might cost those 20 saved frames.TheRealOne wrote:I didn't test from the bb double so these may be slightly off, but I bet it is still faster to turn and use the left wall to ws.
However I took the 0th with just cleaning (I didn't use the begin innov since I couldn't do it and was lazy to analyze your demo :P)
EDIT: 9-0
EDIT: 97-0, I came up with this idea a while back, but didn't really think anything much of it. Not really sure where the drones will end up, but just posting it to add to the brainstorm of innovation. Van made the demo. Getting all of the gold on the fall should be possible.
nice locked door jump there! not sure if it helps, though, but definitely speeds you up (maybe in the wrong direction)TheRealOne wrote: 9-0
Improvement: An extra gold, or even 2 extra gold, so 2 or even 4 seconds better.
Demo:
Another Demo (To prove it wasnt luck):
Yeah, so taking those golds is possible, I supose you already knew it, you can also take the right one (I supose).
I did it realtime and im usually able to do it like 1/15 times more or less.
I left it there...
I KNEW IT WAS POSSIBLE! niceEddyMataGallos wrote:Level: 97-2
but i think the right one is not possible because the drone isn't at the very left spot at the beginning (it's a little more to right)
Thanks, and well if you see my demo, you'll see that the drone isnt at the very right spot at the beggining too, because I put it a bit to the left on purpose just to start as on the beggining of the level, however, the right one is much more difficult because you would need to do 2 wjs in order to be enough fast, as there is no floor...vankusss wrote:I KNEW IT WAS POSSIBLE! niceEddyMataGallos wrote:Level: 97-2
Proof that it is possible on the right side as well.EddyMataGallos wrote:Level: 97-2
Demo:
I left it there...
The trick to both side is doing a bwj on the 8 tile so that you clip 8 tile on the end of the platform the FG is on. This lets you get as far in to the tunnel as possible before the FG sees you. I actually had a few frames to spare in my run so it is certainly possible real time, but not very easy. Getting the right gold is harder than the left gold just because you have to jump of a sloped surface instead of flat ground, but it is also earlier in the run so if you mess up it isn't a huge deal to redo up to there.
EDIT: New idea. Gather a list of all of the levels that have missed gold that is possible to get. Develop routes for these levels and call it operation AGD.
The list so far:
5-4
15-3
27-0
31-4
38-4
43-0
51-3
58-1
58-3
64-4
83-3
91-4
96-4
97-2 (^^^)
I am pretty sure this has been suggested before and been found to be slower, but I wasn't sure so I am just posting this here to I remember to test this against the chimney route.
I was trying to make a route for AGD and thought of this innovation, but still had to work on the route. It became more complicated than I thought so I didn't finish the route. Just posting this for brainstorm sake.
This may help anyone who is interested in making a new route. It is kind of confusing but dots of the same color show what is being grabbed at once.
That looks really promising, nice find. Now just find someone to find&execute the rest.TheRealOne wrote:Map: 43-0
Also on 45-4, i've tried doing gold first, might work, too. Eddy is losing only 1 second with the first route that I saw and without Izzy's drone section, so I would say it's faster with some modificiations.
at first meant for sr, but it might be included in some cool hs route, so i just put it here for the record
nice, raif or TRO, do you think we can have this bad boy MBD'd?vankusss wrote:37-4 hs
Doing a double bbbwj.
Using only the first bounceblock to jump off of.
I think you may have to jump off only the second one and at a good angle to actually make this route happen properly.
I think this would be faster for the middle section than jump back across to get the bottom two in one fall.
Ill try for a few more minutes to get the AGD, but I have class soon, so I figure I would just post it.
Nice, but someone should test it first.TheRealOne wrote:Map: 61-2
Also, this for the beginning:
How about something like this for the middle section?vankusss wrote:Nice, but someone should test it first.TheRealOne wrote:Map: 61-2
or maybe even this?
That first thing is awesome and definitely faster, I'm convinced the 2nd one isn't possible agd.glib_jase wrote: How about something like this for the middle section?
or maybe even this?
Don't know who wants to go my new begin + glib mid + my end, that's really really hard altogether.
Yup thats the route. Do it glib, great find.vankusss wrote:That first thing is awesome and definitely faster, I'm convinced the 2nd one isn't possible agd.glib_jase wrote: How about something like this for the middle section?
or maybe even this?
EDIT: Also we should take a look at 61-4 there HAS to be a new route for that map. I wouldn't be surprised if there was 10 seconds left for MDB(corner jump madness). Probably a decent amount left for real time.
This CJ is pretty easy and would save a bit. But I have a feeling there is a better route over all, though you are constrained by the back and forth key system.
this is more like what i had..
That is almost the exact route that I posted...? Jumping from the floor before the 8 tile is certainly faster as glib demonstrated.ska wrote:actually.. it's not quite what I had in mind...
Users browsing this forum: Google [Bot] and 16 guests
