Postby vankusss » 2011.10.12 (10:23)
Unreality wrote:have you copied the 6g2.swf to the folder too?
have you tried restarting the exe?
I downloaded the newest version from your site, I assume there is everything needed? There already is NReality_v6g2.exe.
I tried multiple times :).
Postby Unreality » 2011.10.12 (10:26)
are you using the NRealityIRC6g2.exe ? is there NReality_v6g2.swf in your folder?
Postby vankusss » 2011.10.12 (22:33)
Unreality wrote:are you using the NRealityIRC6g2.exe ? is there NReality_v6g2.swf in your folder?
I'm just reporting that it works now. The problem was probably with my laptop running on battery and having some shit performance. Sorry I didn't figure that out back then :/
And it's really cool, thanks for the feature :) Though a lot of people seem to be having problems with it, after talking with few on the old irc.
M&R need to have some big ace in their sleeve (is that the english expression, lol?), otherwise I really don't see a reason to abandon NReality for 1.5.
My cup of tea was poured!
Postby Unreality » 2011.10.13 (14:38)
thx vankuss for letting me know how you solved the problem :)
and here's a way to join NReality IRC : http://tinyurl.com/nrealityIRC
Postby TheRealOne » 2011.10.13 (20:40)
So I think I have discovered another bug. When I try and paste map data in to NED it does not load the level when I press L. It just reloads the map that is already loaded.
Postby golf » 2011.10.15 (01:07)
golf wrote:Woo chat! Got a couple things to be worked out before I think it'll be enough for me to really want to use though. I don't mind the small entry area, just makes talking a little bit of an adventure :) I would like (1)to be able to use the demo replay and enter NUMA maps to play, and also (2)have the chat entry inputs separate from in-game inputs, so that typing in chat doesn't pause/unpause the game, or potentially suicide you.
I've got the new version, and here's my thoughts based on what I said before. Still love being able to have chat, and I think the best difference is moving it over to the side. Now we can see what we type :D
1: Thank you for fixing this, it will make competing on NUMA maps so much easier now once enough people start to switch over to 6g2IRC.
2: Unfortunately I still have the same issue. For me, once this is ironed out this will probably be the main version of NReality I use.
Postby aids » 2011.10.16 (10:48)
So, this happened:
Click.
I'm not sure why.
Postby Unreality » 2011.10.16 (12:50)
@golfkid, I will find a solution to #2
@Aidiera, use mouse to drag instead of maximizing it
Postby amomentlikethis » 2011.10.17 (21:07)
A next/prev button on userlevels for changing map would be cool.
Hi.
Postby ska » 2011.12.27 (07:09)
I found a bug in 6g2 where in NED, every time I try and click off the level or demo data box, the text cursor won't disappear which makes mapping really annoying because it keeps making NaNs. Anyone else found this? I wasn't using the one with IRC either, so that doesn't seem to be the problem, although I'm guessing this build retained the cursor from the IRC addon which is probably what's screwing it up. I guess it's the same with the IRC version. 6g did not have this as far as I can recall.
Postby TheRealOne » 2011.12.28 (20:58)
ska wrote:I found a bug in 6g2 where in NED, every time I try and click off the level or demo data box, the text cursor won't disappear which makes mapping really annoying because it keeps making NaNs. Anyone else found this? I wasn't using the one with IRC either, so that doesn't seem to be the problem, although I'm guessing this build retained the cursor from the IRC addon which is probably what's screwing it up. I guess it's the same with the IRC version. 6g did not have this as far as I can recall.
Yeah this glitch came about in v6e, which Unreality only released to a few of us who happen to be in IRC one day. I noticed this when I was trying to MDB. Maybe it has something to do with display state because that was the only change in v6e as far as i know, but I doubt that would have anything to do with it.
But yes I agree this glitch is very aggravating. The cursor needs to leave both the level and demo box when clicking on the background.
Triforce
NUMA Profile: http://www.nmaps.net/user/dante_allege
Postby danteallege » 2012.01.15 (00:25)
Apologies if this has already been asked before, but does this also apply to Mac? I don't want to download it, only to find it doesn't work and it's deleted all my progress, meaning I then have to copy my backed-up version in. Too much effort for me :) Thanks in advance!
Lucky
Postby Miststalker06 » 2012.05.25 (18:10)
6g2 doesn't work with foreground images. Just a heads up! It doesn't even load the foreground image.
NUMA Profile: http://nmaps.net/user/Ors_II
Postby Ors » 2012.12.13 (13:45)
Miststalker06 wrote:6g2 doesn't work with foreground images. Just a heads up! It doesn't even load the foreground image.
I have a same problem. n.infunity.com/ doesn´t work too...
My youtube channel:http://www.youtube.com/user/Ors2011
My NUMA user: http://www.nmaps.net/user/Ors_II
Interested about advanced N-arts? Get a link to N-Artist v1.0 here.
Postby zoasBE » 2013.06.05 (01:26)
I think it works perfectly if you use the normal app without IRC chat. Using the version with IRC integrated the images doesn't load, but you have in the same folder the version without it. Just use the normal one without IRC, it runs frankly smoothly.
just as friends as enemies
even fewer friends
Postby zoasBE » 2013.06.05 (01:59)
I usually solve this problem (when mapping at Ned in NReality) by clicking in the text box for the demo. You can reload your objects and everything else and continue mapping without any NaN'd objects appear.
even fewer friends
Postby EddyMataGallos » 2014.09.26 (22:50)
MiBeM wrote:
Izzy wrote:
MiBeM (back in 2010) wrote:Speedrun mode needs some kind of a frame counter.
Under the time bar at the top left?
Exactly.
This is hilarious.
