-0 has innovated beggining and ending. Beating that last drone could be possible with some other change. Actually if you manage to beat the drone at the top after the switch, you could go right instead of left first.
very nice runs... I always felt that 11-0 could be done more efficiently (especially the ending.) so good job.EddyMataGallos wrote:Took 11-0, -1 and -2. Tied -3. Was going for ownage till I saw -4 haha.
Mibem, if you decide to go back to 49-4 (or anybody else, for that matter), how about a bbwj going into the last switch before the exit off the set of bounceblocks second from the left. Hopefully it makes sense what I'm trying to say there... I know its at the end of a longish run, especially in speedrunning standards, and its pretty tricky to pull off a jump like that but I feel like that would definitely save some time.
I did some testing on the ending to find the fastest way I could do it, and it turned out to be this:
$49-4 Ending With Straight CJ#MiBeM#test#11000000000001150211111000000000000011000111110000000000000110000021100000000000001100000011000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000|5^564,564!1^108,516!1^108,492!1^252,516!1^252,492!11^60,396,60,396!12^60,420!12^24,420#165:17895697|17895697|17895697|17895697|17895697|17895697|17895697|17895697|17895697|17895697|17895697|17895697|17895697|89985297|89478485|97587541|18175317|17895697|17895697|17895697|17895697|17895697|107405585|26214Btw, very nice run on 45-1 danielr. I thought about that ending trick when I was doing my run on the level but I didn't have enough skill at the time.
Very nice run, MiBeM.MiBeM wrote:Got a better run on 49-4. The ending could be improved a little but other than that I think this is one of my best runs yet.
I did some testing on the ending to find the fastest way I could do it, and it turned out to be this:However it's extremely hard to hit that without getting caught under the bb so I chose the second best option which was only 3 frames slower in my tests.Code: Select all
Two things though:
1) Please use the "map" button for any map/demo/userlevel data as "code" cuts it off and makes it unwatchable.
2) I think you mean 45-0, not 45-1?
I find it suspicious that you know that much about how the guy thinks. Is there any relationship going on?ska wrote:I think you mean 45-0?
Damn, I fail numbers a lot. Yup, that's what I meant :Pska wrote:I think you mean 45-0, not 45-1?
Here's the slightly faster way to do the ending, this time in a "map" box.
The demo in the "code" box seemed to work as well though. Maybe it only breaks longer runs.
Yeah, I didn't actually check it, but I know it breaks longer runs, so I just assumed this too was broken. It's also much easier to copy in the "demo" box.MiBeM wrote:Damn, I fail numbers a lot. Yup, that's what I meant :Pska wrote:I think you mean 45-0, not 45-1?
Well you can actually click "Select all" on codes so that makes it real quick, though I understand Im not used to it neither.ska wrote:Yeah, I didn't actually check it, but I know it breaks longer runs, so I just assumed this too was broken. It's also much easier to copy in the "demo" box.MiBeM wrote:Damn, I fail numbers a lot. Yup, that's what I meant :Pska wrote:I think you mean 45-0, not 45-1?
Not sure if you were referring to that by "easier".
Weird... I don't have the "select all" text there... it just says "code" for me...
Thanks! I also took level 47-3 afterwards.ska wrote:Nice runs, man :)
Good job... is that drone at the end a bottleneck?MiBeM wrote:Thanks! I also took level 47-3 afterwards.ska wrote:Nice runs, man :)
I'm not entirely sure what you mean by that. You can lure it away at the start so it's not in the way at the end like I accidentally did in my episode run but it doesn't really make a difference. Otherwise you have to be fast (or slow) enough to get past it.ska wrote:is that drone at the end a bottleneck?
