Postby MiBeM » 2013.11.04 (13:15)
Retook 5-0 with a little innov at the end. Gonna try ska's route on 44-2 now.
a.k.a. MoleTrooper/Molenator
Speedruns and stuff
Postby MiBeM » 2013.11.04 (15:22)
Actually, screw ska's route. I've got something better. ;)
Speedruns and stuff
Postby macrohenry » 2013.11.04 (15:35)
I'm surprised that no one did that before you. Great run although it can be cleaned a lot.
Postby MiBeM » 2013.11.06 (16:26)
Took 181-0 with a new route.
Speedruns and stuff
Postby EddyMataGallos » 2013.11.08 (19:02)
Took 11-0, -1 and -2. Tied -3. Was going for ownage till I saw -4 haha.
-0 has innovated beggining and ending. Beating that last drone could be possible with some other change. Actually if you manage to beat the drone at the top after the switch, you could go right instead of left first.
Postby ska » 2013.11.08 (22:43)
EddyMataGallos wrote:Took 11-0, -1 and -2. Tied -3. Was going for ownage till I saw -4 haha.
very nice runs... I always felt that 11-0 could be done more efficiently (especially the ending.) so good job.
Postby MiBeM » 2013.11.09 (16:31)
Cleaned up my 44-2 run for a bit, got about half a second off.
Speedruns and stuff
Postby MiBeM » 2013.11.11 (16:13)
Took 49-4 with a couple of little innovs. Not amazingly clean but I'm done playing for today.
Speedruns and stuff
Postby _danielr_ » 2013.11.11 (22:52)
45-0
Wait for it...
Postby golf » 2013.11.11 (23:04)
Great ending on 45-0 daniel, I can see that being used in hs mode too.
Mibem, if you decide to go back to 49-4 (or anybody else, for that matter), how about a bbwj going into the last switch before the exit off the set of bounceblocks second from the left. Hopefully it makes sense what I'm trying to say there... I know its at the end of a longish run, especially in speedrunning standards, and its pretty tricky to pull off a jump like that but I feel like that would definitely save some time.
Postby MiBeM » 2013.11.12 (14:06)
Got a better run on 49-4. The ending could be improved a little but other than that I think this is one of my best runs yet.
I did some testing on the ending to find the fastest way I could do it, and it turned out to be this:
$49-4 Ending With Straight CJ#MiBeM#test#11000000000001150211111000000000000011000111110000000000000110000021100000000000001100000011000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000|5^564,564!1^108,516!1^108,492!1^252,516!1^252,492!11^60,396,60,396!12^60,420!12^24,420#165:17895697|17895697|17895697|17895697|17895697|17895697|17895697|17895697|17895697|17895697|17895697|17895697|17895697|89985297|89478485|97587541|18175317|17895697|17895697|17895697|17895697|17895697|107405585|26214
However it's extremely hard to hit that without getting caught under the bb so I chose the second best option which was only 3 frames slower in my tests.
Btw, very nice run on 45-1 danielr. I thought about that ending trick when I was doing my run on the level but I didn't have enough skill at the time.
Speedruns and stuff
Postby macrohenry » 2013.11.12 (14:15)
That ending in your 0th run is GENIUS! :o
Postby ska » 2013.11.12 (15:59)
MiBeM wrote:Got a better run on 49-4. The ending could be improved a little but other than that I think this is one of my best runs yet.
Very nice run, MiBeM.
Two things though:
1) Please use the "map" button for any map/demo/userlevel data as "code" cuts it off and makes it unwatchable.
2) I think you mean 45-0, not 45-1?
Postby vankusss » 2013.11.12 (16:04)
ska wrote:I think you mean 45-0?
I find it suspicious that you know that much about how the guy thinks. Is there any relationship going on?
Postby MiBeM » 2013.11.12 (16:13)
ska wrote:I think you mean 45-0, not 45-1?
Damn, I fail numbers a lot. Yup, that's what I meant :P
Here's the slightly faster way to do the ending, this time in a "map" box.
The demo in the "code" box seemed to work as well though. Maybe it only breaks longer runs.
Speedruns and stuff
Postby ska » 2013.11.12 (19:34)
Yeah, I didn't actually check it, but I know it breaks longer runs, so I just assumed this too was broken. It's also much easier to copy in the "demo" box.
Postby EddyMataGallos » 2013.11.12 (21:13)
Well you can actually click "Select all" on codes so that makes it real quick, though I understand Im not used to it neither.
Postby ska » 2013.11.13 (03:02)
Do you mean "demo" not "code", Ed? :P
Postby EddyMataGallos » 2013.11.13 (15:49)
Oh well I was talking about copying from a code box
Not sure if you were referring to that by "easier".
Postby ska » 2013.11.13 (22:38)
O_o
Weird... I don't have the "select all" text there... it just says "code" for me...
Postby MiBeM » 2013.11.22 (15:02)
ep 47, my best episode run so far I think.
Speedruns and stuff
Postby ska » 2013.11.22 (16:18)
Nice runs, man :)
Postby MiBeM » 2013.11.22 (17:15)
ska wrote:Nice runs, man :)
Thanks! I also took level 47-3 afterwards.
Speedruns and stuff
Postby ska » 2013.11.23 (03:41)
Good job... is that drone at the end a bottleneck?
Postby MiBeM » 2013.11.23 (10:23)
ska wrote:is that drone at the end a bottleneck?
I'm not entirely sure what you mean by that. You can lure it away at the start so it's not in the way at the end like I accidentally did in my episode run but it doesn't really make a difference. Otherwise you have to be fast (or slow) enough to get past it.
Speedruns and stuff
Users browsing this forum: No registered users and 52 guests
