Nv2.0 User levels 0ths
Discuss the Metanet map server and the submissions to it
Moderator: XandoToaster
Postby james_S » 2013.12.14 (20:13)
Ola!
errr crazy map that Lorenzo's super challenge.
Mina '' Simple challenge 000 '' www.thewayoftheninja.org/nv2.html?l=30216 -plus I'm think there's another Daring (max longest jump required) route because I almost managed it :P
Postby james_S » 2013.12.14 (20:24)
aww gottu love that, massive map twice cheatable. to be fair though those jumps are pretty cool...
NUMA Profile: http://www.nmaps.net/user/thrasher26
Postby thrasher26 » 2013.12.14 (20:36)
Tremendo demo Eddy al igual que tu James
Eso fue lo primero que intente cuando vi el mapa, me lanzaba, vi que el ninja se golpeaba ahí pero yo no alcanzaba a saltar Image
Sos el amo de este juego Edyy Image
Postby james_S » 2013.12.14 (21:05)
pretty funny how google translate gave the word ''tremendous'' :) Gracias T26 but c'mon I think Eddy is a lot better player than myself
Postby M4xwell » 2013.12.14 (23:55)
james_S wrote:pretty funny how google translate gave the word ''tremendous'' :) Gracias T26 but c'mon I think Eddy is a lot better player than myself
You are all good, great even. (A lot better than I.)
"...well then."
Sponsered by panstromek...
Postby M4xwell » 2013.12.15 (00:03)
http://www.thewayoftheninja.org/nv2.html?l=30092 (02-3)
Carry Me Home, My Zephyr - M4xwell. Honestly didn't think it was hard, just needed quick jumping skills. (I messed up on the left top corner portion, you'll see.)
"...well then."
Postby thrasher26 » 2013.12.15 (04:36)
¿Por que soy el unico highscorer en este mapa?
mercurial by Losttortuga
http://www.thewayoftheninja.org/nv2.html?l=29812
Creo que buenos excelentes saltadores como Eddy, Innevitability, thejumper741, jp27ace...
pueden hacerlo mucho mejor, incluso lograr limpiamente un AGD.
(No se si la pieza de oro que no cogi tiene mas oro de lo normal).
Postby james_S » 2013.12.17 (23:34)
Hey dajumpah741, I tied with you on Fujita's Sharei www.thewayoftheninja.org/nv2.html?l=31124 =) going by a different route too..
Postby Inevitability » 2013.12.18 (07:58)
james_S wrote:Hey dajumpah741, I tied with you on Fujita's Sharei http://www.thewayoftheninja.org/nv2.html?l=31124 =) going by a different route too..
Yeah, the route itself is pretty good (at least i can't think of something better), so i decided not to play this map.
Anyway, it can be impoved like this
and you can also outrun the drone between two squares at the beginning (above it with cleaner jumps)
thrasher26 wrote:Creo que buenos excelentes saltadores como Eddy, Innevitability, thejumper741, jp27ace...
Speaking of the best active user maps players, i would definitely mention (in addition) Quintal, swipenet, White Whale and maybe even
Oleary15, Cerberus, yougotPWND and Karudia
Oh, and danielr, of course. He is awesome =)
And I'm still a noob.
Postby thejumper£#! » 2013.12.18 (23:55)
Good work jamesss but some other guru has taken the 0th. :)
I don't know if is possible to do the jump that you have designed, Inevitability-not-noob, the funny-green-killer-floorguard start running even if you don't have touched the floor.
But i can't test it because my gpu (my lovely, expensive and outside-warranty gpu -.-) is broken :( and i can't play some level because the game run inconstantly and at low fps, is not fluid, is terrible play in this way...
thecircus741: Drone-trainer
Postby M4xwell » 2013.12.19 (00:55)
http://www.thewayoftheninja.org/nv2.html?l=31488 My God I made a map to test even the best of N players...
EDIT: (0th for now) I have a VERY sloppy run, but I just wanted to show that it's beatable.
"...well then."
Postby james_S » 2013.12.19 (01:17)
lol, well about the Sharei map that route I (and Eddy) took is limited by the bottom right drone.. But its nice to see now how to outrun the drone in the first part -i.e first run close to the wall, then jump -and not too powerfully so as not to overshoot (like EMG did).
I do wonder about the time difference between mine and Eddy's ending route...?
Its cool when by chance the fastest route on a map turns out to have some obstacle making it critical that u dont slow down eh :) -like the last drone on jp27ace's run. Nice run(!)
Gd luck with your comp jumper.
Maxwell, sexy map that I'll try to play it tomorrow
Postby EddyMataGallos » 2013.12.19 (16:23)
james_S wrote: Its cool when by chance the fastest route on a map turns out to have some obstacle making it critical that u dont slow down eh :) -like the last drone on jp27ace's run. Nice run(!)
That drone can be beaten (check my run), but nice route jp ;)
In fact you can double beat it (make it detect you on the tile before).
EDIT: Sorry I did the double beat so you can't see whats just beating it, its basically making it detect you on the next vertical line, so on the left, by going a little slower.
Postby james_S » 2013.12.19 (17:35)
-interesting stuff. My old run was interesting, when I was going slower the top right drone would run down at me as I was leaving that room -but I did the wall jump you have to do extra early and so managed to jump over the drone. but yea that doesnt matter heh
Postby M4xwell » 2013.12.19 (23:38)
James, I like your run on Vines http://www.thewayoftheninja.org/nv2.html?l=10665 but i feel like it can easily become an AGD though (with higher score)
"...well then."
Postby james_S » 2013.12.20 (20:02)
-thats not a new map is it judging by the map number? I improved it a bit -it was quite fun. But c'mon, an exercise for you- what do you think are the limitations of that map ? :)
I can mention a thing I'm not a fan of now -cause its the same problem I had on my Fujita collab, the bottom left gold on your map is boring to collect as you have to stop in teh middle of nowhere and just do a slow basic jump. On the fujita collab http://www.thewayoftheninja.org/nv2.html?l=25789 I didnt like the rocket gold for the same reason -if I could remake it i would make the block gate not block the exit like it does now but just partially block a route so you have to do a pro jump to get around it -that way you on the best route you would jump with full speed at that gold.. -Im not gonna do a remake though :(
ps tall about nice runs, you're a funny guy(!) doing that move on the '' Tnx m4xwell '' map where u jumped into a convoy of 2 drones
Postby M4xwell » 2013.12.20 (22:04)
james_S wrote:ps tall about nice runs, you're a funny guy(!) doing that move on the '' Tnx m4xwell '' map where u jumped into a convoy of 2 drones
I had no idea that i was going to make that, but i laughed and plated it off cool when i did so.
james_S wrote:the bottom left gold on your map is boring to collect as you have to stop in teh middle of nowhere and just do a slow basic jump.
I'm confused onto what hap you're talking about.
Also, I got 0th for 'Apache Didn't Jump On It...' http://www.thewayoftheninja.org/nv2.html?l=30813 . In my opinion, VERY difficult.
"...well then."
I had no idea that i was going to make that, but i laughed and played it off cool when i did so.
I'm confused onto what map you're talking about, but i see your point. Usually, I feel scared because i feel that some maps of mine LACK of gold and therefore i put extra.
"...well then."
Postby thejumper£#! » 2013.12.20 (23:54)
ghghgh my 0th (for the moment - EDIT: overcome by LuxxiZ ehehe) in 173 pit - STORM - http://www.thewayoftheninja.org/nv2.html?l=32234 - is very funny, not for the run, but for the last jump, I did not know that there was a trap door under the last gold, because I have not seen the replays of other players (I was not yet arrived there), only when I took the gold and not the button of the trap door I'm scared! Then I saw that it was not to block the exit (as do many level's creators), and then so it has been useless. but funny.
Postby EddyMataGallos » 2013.12.21 (00:25)
thejumper£#! wrote:ghghgh my 0th (for the moment - EDIT: overcome by LuxxiZ ehehe) in 173 pit - STORM - http://www.thewayoftheninja.org/nv2.html?l=32234 - is very funny, not for the run, but for the last jump, I did not know that there was a trap door under the last gold, because I have not seen the replays of other players (I was not yet arrived there), only when I took the gold and not the button of the trap door I'm scared! Then I saw that it was not to block the exit (as do many level's creators), and then so it has been useless. but funny.
Nice route there, taken :)
Postby james_S » 2013.12.21 (20:45)
-hey, thats about the wines map you were talking about. Btw i dont think there's too much gold on that map actually -just that that bottom middle left gold could've been made more fun with a ramp or something
(lol thejumper)
Postby james_S » 2013.12.21 (23:32)
...Same thing again: there's a Mystery jump on one of my smallish maps lol. Map: v2.1 Which gear http://www.thewayoftheninja.org/nv2.html?l=32665
EDIT: no mystery jump I know of on the remake. I literally only moved two panels by one space in version v2.1 compared to v.2 but it really freed up the map for me. no more feel of awkwardness and messiness! just power and purity
Postby thejumper£#! » 2013.12.23 (22:22)
in "173 pit" i have updated the run but unfortunately i have pressed the button, is a sad thing... lol
0th in: Janaru - Fujita Seiko - www.thewayoftheninja.org/nv2.html?l=23041
Great level! Why Fujita is not here? The forum wants you. :D
Postby M4xwell » 2013.12.23 (22:46)
thejumper£#! wrote: Why Fujita is not here? The forum wants you. :D
I'm still confused on what Fujita's gender is. :l
"...well then."
Postby thejumper£#! » 2013.12.24 (01:10)
M4xwell wrote:I'm still confused on what Fujita's gender is. :l
Maybe it's a drone. :D
