Nv2.0 User levels 0ths
Moderator: XandoToaster
- Cowboy Magician
errr crazy map that Lorenzo's super challenge.
Mina '' Simple challenge 000 '' www.thewayoftheninja.org/nv2.html?l=30216 -plus I'm think there's another Daring (max longest jump required) route because I almost managed it :P
- Cowboy Magician
- NUMA Profile: http://www.nmaps.net/user/thrasher26
Eso fue lo primero que intente cuando vi el mapa, me lanzaba, vi que el ninja se golpeaba ahí pero yo no alcanzaba a saltar
Sos el amo de este juego Edyy
- Cowboy Magician
- NUMA Profile: http://nmaps.net/user/Zecora
You are all good, great even. (A lot better than I.)james_S wrote:pretty funny how google translate gave the word ''tremendous'' :) Gracias T26 but c'mon I think Eddy is a lot better player than myself
"...well then."
Sponsered by panstromek...
Carry Me Home, My Zephyr - M4xwell. Honestly didn't think it was hard, just needed quick jumping skills. (I messed up on the left top corner portion, you'll see.)
"...well then."
mercurial by Losttortuga
http://www.thewayoftheninja.org/nv2.html?l=29812
Creo que buenos excelentes saltadores como Eddy, Innevitability, thejumper741, jp27ace...
pueden hacerlo mucho mejor, incluso lograr limpiamente un AGD.
(No se si la pieza de oro que no cogi tiene mas oro de lo normal).
- Cowboy Magician
- Member
Yeah, the route itself is pretty good (at least i can't think of something better), so i decided not to play this map.james_S wrote:Hey dajumpah741, I tied with you on Fujita's Sharei http://www.thewayoftheninja.org/nv2.html?l=31124 =) going by a different route too..
Anyway, it can be impoved like this
and you can also outrun the drone between two squares at the beginning (above it with cleaner jumps)
Speaking of the best active user maps players, i would definitely mention (in addition) Quintal, swipenet, White Whale and maybe eventhrasher26 wrote:Creo que buenos excelentes saltadores como Eddy, Innevitability, thejumper741, jp27ace...
Oleary15, Cerberus, yougotPWND and Karudia
Oh, and danielr, of course. He is awesome =)
And I'm still a noob.
I don't know if is possible to do the jump that you have designed, Inevitability-not-noob, the funny-green-killer-floorguard start running even if you don't have touched the floor.
But i can't test it because my gpu (my lovely, expensive and outside-warranty gpu -.-) is broken :( and i can't play some level because the game run inconstantly and at low fps, is not fluid, is terrible play in this way...
thecircus741: Drone-trainer
EDIT: (0th for now) I have a VERY sloppy run, but I just wanted to show that it's beatable.
"...well then."
- Cowboy Magician
I do wonder about the time difference between mine and Eddy's ending route...?
Its cool when by chance the fastest route on a map turns out to have some obstacle making it critical that u dont slow down eh :) -like the last drone on jp27ace's run. Nice run(!)
Gd luck with your comp jumper.
Maxwell, sexy map that I'll try to play it tomorrow
That drone can be beaten (check my run), but nice route jp ;)james_S wrote: Its cool when by chance the fastest route on a map turns out to have some obstacle making it critical that u dont slow down eh :) -like the last drone on jp27ace's run. Nice run(!)
In fact you can double beat it (make it detect you on the tile before).
EDIT: Sorry I did the double beat so you can't see whats just beating it, its basically making it detect you on the next vertical line, so on the left, by going a little slower.
- Cowboy Magician
"...well then."
- Cowboy Magician
I can mention a thing I'm not a fan of now -cause its the same problem I had on my Fujita collab, the bottom left gold on your map is boring to collect as you have to stop in teh middle of nowhere and just do a slow basic jump. On the fujita collab http://www.thewayoftheninja.org/nv2.html?l=25789 I didnt like the rocket gold for the same reason -if I could remake it i would make the block gate not block the exit like it does now but just partially block a route so you have to do a pro jump to get around it -that way you on the best route you would jump with full speed at that gold.. -Im not gonna do a remake though :(
ps tall about nice runs, you're a funny guy(!) doing that move on the '' Tnx m4xwell '' map where u jumped into a convoy of 2 drones
I had no idea that i was going to make that, but i laughed and plated it off cool when i did so.james_S wrote:ps tall about nice runs, you're a funny guy(!) doing that move on the '' Tnx m4xwell '' map where u jumped into a convoy of 2 drones
I'm confused onto what hap you're talking about.james_S wrote:the bottom left gold on your map is boring to collect as you have to stop in teh middle of nowhere and just do a slow basic jump.
Also, I got 0th for 'Apache Didn't Jump On It...' http://www.thewayoftheninja.org/nv2.html?l=30813 . In my opinion, VERY difficult.
"...well then."
I had no idea that i was going to make that, but i laughed and played it off cool when i did so.james_S wrote:ps tall about nice runs, you're a funny guy(!) doing that move on the '' Tnx m4xwell '' map where u jumped into a convoy of 2 drones
I'm confused onto what map you're talking about, but i see your point. Usually, I feel scared because i feel that some maps of mine LACK of gold and therefore i put extra.james_S wrote:the bottom left gold on your map is boring to collect as you have to stop in teh middle of nowhere and just do a slow basic jump.
"...well then."
Nice route there, taken :)thejumper£#! wrote:ghghgh my 0th (for the moment - EDIT: overcome by LuxxiZ ehehe) in 173 pit - STORM - http://www.thewayoftheninja.org/nv2.html?l=32234 - is very funny, not for the run, but for the last jump, I did not know that there was a trap door under the last gold, because I have not seen the replays of other players (I was not yet arrived there), only when I took the gold and not the button of the trap door I'm scared! Then I saw that it was not to block the exit (as do many level's creators), and then so it has been useless. but funny.
- Cowboy Magician
M4xwell wrote:I had no idea that i was going to make that, but i laughed and played it off cool when i did so.james_S wrote:ps tall about nice runs, you're a funny guy(!) doing that move on the '' Tnx m4xwell '' map where u jumped into a convoy of 2 drones
-hey, thats about the wines map you were talking about. Btw i dont think there's too much gold on that map actually -just that that bottom middle left gold could've been made more fun with a ramp or something
(lol thejumper)
- Cowboy Magician
EDIT: no mystery jump I know of on the remake. I literally only moved two panels by one space in version v2.1 compared to v.2 but it really freed up the map for me. no more feel of awkwardness and messiness! just power and purity
0th in: Janaru - Fujita Seiko - www.thewayoftheninja.org/nv2.html?l=23041
Great level! Why Fujita is not here? The forum wants you. :D
I'm still confused on what Fujita's gender is. :lthejumper£#! wrote: Why Fujita is not here? The forum wants you. :D
"...well then."
Maybe it's a drone. :DM4xwell wrote:I'm still confused on what Fujita's gender is. :l
