Post a Run!
Postby macrohenry » 2013.12.19 (17:55)
golf wrote:Also macro, have you actually been keeping track of my progress through the NReality levels, or are you just saying that because you know that 1000 levels is just a lot of them to go through?
From time to time I check n.infunity.com because I don't want to miss new NReality 0ths that people might not have posted here. And almost everytime I did that I saw your name in the "Latest Level Top-20" section.
golf wrote:I was wondering the same thing, which level it was. Boys, I think we have lookatthis 2.0 on our hands right here!
Was LAT an "innovater"?
Postby golf » 2013.12.19 (18:02)
He was known for making innovations with huge leads over 0th. He innovated 96-4 and 84-0 to both have a 10 second lead over the 0th at the time, and I believe he was the first to get the current 0th route on 78-3 (under the matthewtaylorpowell nick) by beating the drone. He also came onto the scene very fast, similar to you.
Postby jasdanu » 2013.12.28 (08:34)
So I was making a casual run on 231577 when I noticed something weird. During the starting chimney, if you hit the corner fast enough between the 7 tile and E tile it gives you a push. Sometimes its a small one while others its fast enough for the rocket to see you through the tiles. The demo I posted is kept so that I could show you guys the propulsion I mentioned. What is it exactly?
Sig: Izzy
Postby ska » 2013.12.28 (09:32)
jasdanu wrote:So I was making a casual run on 231577 when I noticed something weird. During the starting chimney, if you hit the corner fast enough between the 7 tile and E tile it gives you a push. Sometimes its a small one while others its fast enough for the rocket to see you through the tiles. The demo I posted is kept so that I could show you guys the propulsion I mentioned. What is it exactly?
yeah... i was able to pull this off a few times with relative easy... kinda cool i suppose... i don't know why that happens...
Postby ska » 2014.01.21 (17:17)
231764 hs
Postby alsojp27ace » 2014.01.21 (19:51)
ska wrote:231764 hs
Nice run, you can beat that drone at the start though
Postby ska » 2014.01.22 (09:28)
alsojp27ace wrote:
ska wrote:231764 hs
thanks.
retaken 231764 by over a second.
Postby macrohenry » 2014.01.22 (12:35)
ska wrote:
alsojp27ace wrote:
ska wrote:231764 hs
thanks.
That was very clean! Great run, ska!
Postby ska » 2014.01.23 (14:57)
Thanks. Is there a faster route on 224466 hs? I feel like there is, but I just can't seem to find it.
Postby macrohenry » 2014.01.23 (15:40)
I found one. :) Not a very clean run though.
Postby ska » 2014.01.29 (15:44)
Took 224467. (Current feature map.) Beatable.
Edit: good job on 224466, I figured the drone was beatable with cleanliness. the end is tricky to get right, i know. ;)
Edit 2: took 227615 off Eddy. (probably a frame war map at this point.)
Edit 3: I just realised 224466 and the featured map are one map apart... weird coincidence...
Edit 4: 226971 hs/sr... (another frame war map, perhaps?)
Postby jasdanu » 2014.02.12 (04:05)
Beat my old score on my map 228776
1773:17895697|69905|0|35790848|35791394|35791394|35791394|35791394|35791394|35791394|17895698|17895697|17895697|17895697|4369|35651584|35791394|35792494|17895424|17895697|17895697|17895697|273|35651584|35791394|35791394|2|35791394|35791394|35791394|35791394|17895458|35791409|107880994|36071014|17825792|35795217|40267298|35791394|17826338|17895697|17895697|201326865|107374182|107374182|107374182|107374182|73819750|4|1118464|0|0|0|35791394|139810|0|35790848|35791394|17895680|273|17895697|1118481|16777216|17895697|17895697|0|0|35782656|35791394|16917026|17895697|17895697|69905|0|1118208|0|0|0|0|0|0|0|0|0|0|17825792|0|0|0|139810|17895697|17895697|4369|0|17891328|17|0|0|0|0|0|0|35782656|35791394|35791394|35791394|35791394|35791394|17895682|17895697|17895697|89985297|17895701|17895697|35791633|34|17895697|17895697|17895697|35651601|237117986|107374182|107374182|107374182|107374182|35791462|35791394|74326562|89480192|17895697|89478493|89478485|35651861|35791394|35791394|237117986|107374182|71582822|89478485|89478485|89478485|22369621|89510161|17895697|273|35791360|17825826|17895697|4369|0|4369|35791360|35791394|2|0|0|0|5590016|0|0|0|0|17895680|17895697|1|0|35782656|2|2236416|0|0|0|0|35791392|35791394|35791394|17895714|17895697|17895697|17895697|17895697|33558801|35791394|35791394|107376162|107374182|107374182|107374182|35792486|35791394|35791394|89419298|89478485|89478485|22369621|17895697|17895697|35782657|17891874|17895697|17895697|17895697|79692049|71582788|89474116|71582805|105137220|107374182|107881062|107374182|35808870|34|0|35790848|35791394|107374306|71722598|105137220|107374182|157286|107373644|107234918|35791462|2236962|17895424|0|0|0|0|0|0|35782656|35791394|35791394|34|17895697|35791361|35791394|35791394|17891328|17895697|17895697|17895697|1118481|35791392|35791394|8738|0|1118208|0|0|0|16777762|17
Sig: Izzy
Postby ska » 2014.02.12 (12:05)
jasdanu wrote:Beat my old score on my map 228776
Nice run, but ugh, that map looks tedious as hell to highscore.
Postby ska » 2014.02.14 (00:40)
231879 hs
I'd be impressed with a 104+ score.
Edit 1: 22160 hs
Edit 2: 73295 hs (pleased with this one)
Edit 3: 228732 hs / sr (not much left in this)
Edit 4: 228753 hs /sr (another EMG scalp... for now)
Edit 5: 231997 hs - ok that'll do for now.
Edit 6: 232007 hs
NUMA Profile: http://nmaps.net/user/Wizard2
Postby bugz » 2014.02.20 (11:36)
found this today - n column 00 speedrun. what do you all think?
Postby ska » 2014.02.21 (07:22)
Watched it the other night; mostly on x2 speed. It's a solid run! The only two deaths were strategic suicides and the foresight and route memorization was solid. Can it be beaten? Hell yeah - but you'd need a lot of practice. Does anyone know who this guy is?
Postby vankusss » 2014.02.21 (09:03)
I might be mistaken but I think when we were doing the column speedruns on irc we had around 20-25mins for 00. Didn't watch the whole video but I guess it'd took macro/Eddy like 2 tries to beat it.
Postby ska » 2014.02.21 (09:28)
vankusss wrote:I might be mistaken but I think when we were doing the column speedruns on irc we had around 20-25mins for 00. Didn't watch the whole video but I guess it'd took macro/Eddy like 2 tries to beat it.
I'd try, but I'd constantly fuck up on 03-1.
Postby macrohenry » 2014.02.24 (19:09)
What was that? :O
I've never seen something like that before...
Postby jasdanu » 2014.02.26 (09:40)
macrohenry wrote:What was that? :O
It's sort of a tile and jump-pad propulsion. I've had it happen before. All depends on how you fall nearing the end
Sig: Izzy
Postby ska » 2014.02.26 (12:40)
Yeah... I was gonna say... I have seen this used before, but I can't recall a specific example where this much height was gained. Can anyone else think of one?
Postby macrohenry » 2014.02.26 (17:54)
Nooooooo, so close! :(
Postby jasdanu » 2014.02.27 (07:53)
After tiring my fingers for 10 minutes I finally beat Raif's speedrun on 162592
Sig: Izzy
Postby ska » 2014.02.27 (08:04)
jasdanu wrote:After tiring my fingers for 10 minutes I finally beat Raif's speedrun on 162592
thanks for avenging my demise.
Postby jasdanu » 2014.02.27 (18:33)
:D Yup. But even before this I had beaten Raif by one frame way back when the map was featured. I realized I could shave 1-3 frames off and went at it again. Glad I did
Sig: Izzy
