Postby ska » 2013.06.29 (03:17)
on 2.0, I'd like to see someone pull of an in-between mine jump on b9-4 or use the corners of the single-tiled pits where the drones go.
Postby Raif » 2013.08.18 (21:05)
64-4 innovs
#1
Instead of jumping:
#2
Instead of triple/double on 4 tile:
Note: In this demo I get the 3rd bottom right gold, before climbing this up. This is slower than the normal method.
#3
This is basically #2 + falling into the chamber rightmost chamber to get the piece of gold. This is the only extra gold that would be worth anything in realtime. But even then not by much.
#4
Alternate middle route used in my MBD. Faster but harder.
Postby macrohenry » 2013.10.28 (17:33)
Let's keep this thread alive! :)
1) Compare my 14-2 run with Kool's using ghost mode. At the end, you see that walljumping below the mine is a bit faster.
2) My 51-1 innovation.
Postby ska » 2013.10.28 (18:06)
don't mean to rain on your parade, but I came up with than innov 20 months ago. ;)
Postby macrohenry » 2013.10.28 (18:33)
Oh, cool! But now I wonder why so few people use it, it's not very hard to do.
Postby EddyMataGallos » 2013.10.28 (19:30)
Dafuq, are you telling me that innov was already there when I took the 0th? Damn that hurts. Plus spparently ska's run is 11 days older than mine haha, could have noticed it.
Postby Pheidippides » 2013.12.10 (01:50)
Question: Is there any merit to my start on 26-4 in v2? I say this because the same map is also in v1.4 and because I feel like my score would be fairly high if I could cheat the bounceblock and do awesome walljumps like the rest of you highscoring folk. I have no way to test this, though, and I'm wondering how the m4d sk!llz of a top highscorer would affect the route. Thoughts?
Postby macrohenry » 2013.12.24 (10:05)
We've come up with lots of innovations the past days, so here's another one, for 39-0.
The floorguard on the right and especially the drone in the exit chamber may cause trouble, but maybe you guys can do something with this.
EDIT: I tested this route a bit and it didn't turn out to be faster. :(
Postby _danielr_ » 2014.01.09 (14:33)
New route for 03-4, Nv2.0.
It's not an 0th, but I'm sure it could be...
Taken :)
Postby EddyMataGallos » 2014.01.10 (23:31)
Oh nice innov, cleaned it a bit. Also improved my 00-0 by a frame, I had been some time planning on doing it because I was tired of my 0th demo run to be missing (which I still don't know how it happened) :S
Btw how come that almost nobody is tying 72-2, that level is maxed (without any thwump trick that is) and its easy peasy to get it, when I did it I figured the boards would get full quickly. Come on guys get your spot!
Postby alsojp27ace » 2014.01.11 (01:39)
EddyMataGallos wrote:Oh nice innov, cleaned it a bit. Also improved my 00-0 by a frame, I had been some time planning on doing it because I was tired of my 0th demo run to be missing (which I still don't know how it happened) :S
Very nice 00-0, I can't seem to improve on my score, but I've never been good at frame war levels. It looks like I'm getting close to the bottom of most of the frame war levels in the 00 column actually...
Tied that 72-2, and also came up with a slightly faster route for 03-1 a while ago as we're in a innov thread, but I suck a getting the bottom-left gold.
Postby EddyMataGallos » 2014.01.12 (19:45)
Oh nice route jp, that can save about 50 frames.
Postby 999_Springs » 2014.02.06 (16:54)
EddyMataGallos wrote:Btw how come that almost nobody is tying 72-2, that level is maxed (without any thwump trick that is) and its easy peasy to get it, when I did it I figured the boards would get full quickly. Come on guys get your spot!
tied 72-2, and by the way WHY ARE YOU TALKING ABOUT v2 0THS IN HERE AND NOT IN THE THREAD THAT HAS AMAZING POLLS? surely there's nothing more enticing about a thread than the fact that it keeps a fresh stock of immensely thought-provoking and utterly spectacular polls to vote on periodically!
Postby macrohenry » 2014.02.09 (17:19)
I'm pretty sure that there's a faster route for 91-1 hs. I couldn't find one, but here are some thoughts in the shape of two demos:
Postby alsojp27ace » 2014.02.09 (20:01)
macrohenry wrote:I'm pretty sure that there's a faster route for 91-1 hs. I couldn't find one, but here are some thoughts in the shape of two demos:
I came up with a route similar to that first one for the nv2 version of that level (17-0), due the the drones making the v1.4 route impossible.
I just retook that 17-0 with a time that's faster that than the v1.4 0th, but obviously the drone routes are slightly different, so I don't know whether that will be possible in v1.4
I do like the idea of getting the top gold first but I'm not sure its quicker, I'll have a go at that at some point
Postby golf » 2014.02.10 (02:07)
That first demo, is it possible to do a falling cj to the exit at the end, or are the mines too close to the corner to get that? Seems like that would be faster than falling down to where you were, and using a regular cj to finish.
Postby macrohenry » 2014.02.10 (12:23)
I'm not sure, I've never done a corner jump like this before, but maybe someone else knows if it's possible.
Postby golf » 2014.02.10 (18:40)
macrohenry wrote:I'm not sure, I've never done a corner jump like this before, but maybe someone else knows if it's possible.
I actually took a closer look at it, and I don't think its doable, for a couple reasons. Either its impossible to get any sort of a corner jump there with how close the mine is, or the angle you would have to come in at it means that you wouldn't have enough height to make it over the next platform, so you'd have to do another cj anyways. Looks like that path you've got is probably the best ending to that route.
Postby alsojp27ace » 2014.02.15 (13:03)
Pheidippides wrote:Question: Is there any merit to my start on 26-4 in v2? I say this because the same map is also in v1.4 and because I feel like my score would be fairly high if I could cheat the bounceblock and do awesome walljumps like the rest of you highscoring folk. I have no way to test this, though, and I'm wondering how the m4d sk!llz of a top highscorer would affect the route. Thoughts?
I'm surprised no-one has replied to this sooner, but that's actually a pretty nice route. I've made a few changes to avoid the rockets and added a few extra tricks, but this could definitely be used to take 0th.
Postby ska » 2014.02.15 (13:46)
what is the ep/lvl ID on 1.4 again?
Postby macrohenry » 2014.02.15 (14:21)
48-1. The new route looks awesome, but it's only like 10-15 frames faster and much harder. :(
Postby TheRealOne » 2014.02.15 (21:56)
macrohenry wrote:48-1. The new route looks awesome, but it's only like 10-15 frames faster and much harder. :(
My jaw hit the floor when looking at that route. "looks awesome is an understatement." I hope that get executed some time soon.
Postby ska » 2014.02.16 (09:43)
Yeah. High risk, low reward time-wise, but of course, enough to clinch the 0th if you can hold it together. It would catapult you to an early nomination for run of the year if you can nab it.
Postby macrohenry » 2014.02.26 (14:37)
73-2:
I know, xaelar already beat the drone, but this way it's easier. However, you'll need another innovation to beat the drone on the left.
Also useful for speedruns!
Postby ska » 2014.02.27 (07:57)
macrohenry wrote:73-2:
heh.. that actually looks harder to me with the corner jump. (I'll take your word for it!)
Users browsing this forum: No registered users and 38 guests
