This is tricky, if you don't count the time inbetween the runs, you can just exploit this rule and take a break, or even practise the level in a different computer, which would be technically valid. I know I know, this is very unlikely, but the reason RTA rules are applied is because you need to have exploitproof rules in official comps, and RTA is the most secure method to ensure so.ska wrote:NReality has a built in frame counter in the top-left corner; you could just use that to add up all the frames. No gold calculations required (as it's a speedrun). If the player dies, just take a still frame of the frame count on that death and add it to the tally.This would completely eliminate any discrepancies to do with lag/how fast you can mash the space bar.YetiRevolution wrote:I think the lag is just caused by a slow harddrive. Like Eddy said, it has to write your new PBs to the .sol file, so if your harddrive is failing/slow that takes a long time. Not much to do about it.
Without an accurate way to time the lag I dunno how we'd factor it in to his time :/ The speedrun.com leaderboards are RTA (real time attack) which is usually meant to include all time in the game, except load times that can be accurately accounted for. That said I'm sure he can improve the time with a blank .sol so it probably won't matter for long.I think until macro retries with a blank sol, we should factor in level transition lag into his final time. I think he lost a good 10-15 seconds to lag.
I think it would be really cool if we had a tool that actually counted the in-game frames, but I don't know of a way to do that which accounts for deaths.
Full Column Speedruns
![Image](http://i.imgur.com/Kqd8gBO.png)
![Image](http://i.imgur.com/ViiSEoA.png)
*Except for the few runs like 2-3 and 5-2 where the HS and SR routes are the same.
![Image](http://i112.photobucket.com/albums/n169/Hendor_2006/Userbar-1.png)
- Donator
- Raigan and the Horse-Woman
i will tune in for sure. will there be music or trash talking?DW40 wrote:So I will hopefully be doing a "speedrun" of all columns tomorrow (12th) at http://www.twitch.tv/banjodave. My wrist is a little messed up though so we'll see how that goes.
![spoiler](https://i.imgur.com/dMfahpY.png)
- Donator
No music cos I don't want to get banned or anything. I will be mic'd up though.nevada wrote:i will tune in for sure. will there be music or trash talking?DW40 wrote:So I will hopefully be doing a "speedrun" of all columns tomorrow (12th) at http://www.twitch.tv/banjodave. My wrist is a little messed up though so we'll see how that goes.
- Semimember
Curious to see how it will go! I've been thinking about doing one for a while, but I need to actually learn the routes for the hard levels first.DW40 wrote:So I will hopefully be doing a "speedrun" of all columns tomorrow (12th) at http://www.twitch.tv/banjodave. My wrist is a little messed up though so we'll see how that goes.
Edit: Just did some runs vs Macro's splits. I can save about 15 seconds each on ep06 and ep09...it's just a matter of doing that without losing time everywhere else :/
- Donator
I'm going to start at 1pm GMTEddyMataGallos wrote:Good luck, I won't be able to see it because I'm pretty busy and this stream will be very long xD However, if you decide the start time on beforehand try to post it here, I might be able to tune in every now and then to see how its doing.
It's a shame I'll be asleep for probably all, or at least most, of your run. Regardless, please make sure you have a time overlay so we can get a sense of your projected finish time, and that the feat if properly recorded. My prediction is that you will take about 2 hours off 999 Spring's time.DW40 wrote:I'm going to start at 1pm GMTEddyMataGallos wrote:Good luck, I won't be able to see it because I'm pretty busy and this stream will be very long xD However, if you decide the start time on beforehand try to post it here, I might be able to tune in every now and then to see how its doing.
good luck with that - you're obviously much more well-prepared than i am, and it would be fun to watch as long as i get my fucking adobe flash player working again. try to not get too frustrated with the 80's column. i secretly hate you because i was hoping to hold the record for full game speedrun forever, but no hard feelingsDW40 wrote:So I will hopefully be doing a "speedrun" of all columns tomorrow (12th) at http://www.twitch.tv/banjodave. My wrist is a little messed up though so we'll see how that goes.
i'm in the same timezone as dw40 is so i'll be able to watch the whole thing. but with preparation i think he would easily take 3 hours off, since when i did it my goal was to beat it within a day, not necessarily a speedrun. also i spent like an hour watching live stand-up comedy, 15 minutes in total writing up the log as i went along, and about 20-30(?) minutes eating, all of which are totally unnecessary for a speedrunska wrote:It's a shame I'll be asleep for probably all, or at least most, of your run. Regardless, please make sure you have a time overlay so we can get a sense of your projected finish time, and that the feat if properly recorded. My prediction is that you will take about 2 hours off 999 Spring's time.DW40 wrote:I'm going to start at 1pm GMTEddyMataGallos wrote:Good luck, I won't be able to see it because I'm pretty busy and this stream will be very long xD However, if you decide the start time on beforehand try to post it here, I might be able to tune in every now and then to see how its doing.
EDIT: i didn't realise it was happening right now i thought today was the 11th >.<
EDIT: ok i'm watching you now
here are the splits:
column me you
00-09 0:33 0:27
10-19 1:01 0:56
20-29 1:53 1:34
30-39 2:40 2:25
40-49 3:40 3:01
50-59 4:44 3:57
60-69 5:27 4:29
70-79 6:20 5:22
80-89 10:08 7:08 <-- i had a long break during this column
90-99 11:10 7:51
my estimate wasn't far off
- Donator
- Semimember
- Donator
Thanks man. With a crazy amount of practice, maybe it can go as low as 5 hours. I don't think it should matter which order you do the columns in either.YetiRevolution wrote:Nice run DW40 :D How low do you think the time could go with lots of practice/etc? Also I noticed that you do the columns in order. Do you all think that should be required for the category, or should you be allowed to start with the hard columns to get them out of the way first, since the game technically doesn't care which one you start on?
If you want my opinion, I think it can be taken under 4 hours, based on Analu's column speedrun scores, which if they are legit and I added them properly, sum barely over 4 hours, and I don't think he really put a lot of effort into the later columns, nor practise on beforehand, so I'd be surprised if those scores are tight, I mean even his Column 00 run is 24 minutes, which one can get with barely any practise on beforehand (and we can expect this column to be the cleanest on his list).DW40 wrote:YetiRevolution wrote:Nice run DW40 :D How low do you think the time could go with lots of practice/etc? Also I noticed that you do the columns in order. Do you all think that should be required for the category, or should you be allowed to start with the hard columns to get them out of the way first, since the game technically doesn't care which one you start on?
So beating those times barely would already yield sub-4h. Then again, I haven't speedrunned any column so I'm not sure how fast those scores are, since there's no comparison nor video. But based on Column 00, that's the feeling I get.
I also remember being on IRC a while ago speedrunning Column 20 with some people, van and I beat it in 20 minutes iirc, which is 10 minutes faster than Analu, and we hadn't practised at all, it was improvised. So that leads me to think Analu didn't really practise on beforehand either, because lets be honest, who is gods name would practise all 500 levels on beforehand? xD
Of course, I could be wrong and those column scores could be super tight :P Also, even if the scores aren't tight, it might be tough to stay focused for such a long time, and tiredness is certainly a factor.
- Semimember
- Semimember
Here's the VOD: http://www.twitch.tv/ffatv/c/5874270
Or youtube, if you prefer: https://www.youtube.com/watch?v=PEZE2nq ... tube_gdata
I just did, managed an unclean 18:06 with a couple deaths on my third completion. I'm not even uploading the video because I'll be going for sub-18 soon, was going to do it today, but I lost my focus and I'm dying too much now, so I'll try again tomorrow with a fresh mind. I think I can pull it down to 17:30 if I manage no mistakes, I mean, based on the main time wastes I had in this run and the previous one.YetiRevolution wrote:Just managed an 18:23 on column 00. Not a perfect run, since I had one small death on 08-1, and my movement wasn't great in a lot of places. Overall though I'm happy with it, and will probably take a break from column 00 even if someone beats me :p
Wow. I laughed when that cat was causing a raucous. And by the end it sounded like you orgasmed. Congrats on the WR, and thanks for commentating. I hope macro commentates a response run.YetiRevolution wrote:Just managed an 18:23 on column 00. Not a perfect run, since I had one small death on 08-1, and my movement wasn't great in a lot of places. Overall though I'm happy with it, and will probably take a break from column 00 even if someone beats me :p
- Semimember
Grats, that confirms my suspicion that I won't be able to compete with high scorers in the long run. Oh well, I'm happy to have gotten the time I did, and maybe I'll try some other columns.EddyMataGallos wrote:I just did, managed an unclean 18:06 with a couple deaths on my third completion. I'm not even uploading the video because I'll be going for sub-18 soon, was going to do it today, but I lost my focus and I'm dying too much now, so I'll try again tomorrow with a fresh mind. I think I can pull it down to 17:30 if I manage no mistakes, I mean, based on the main time wastes I had in this run and the previous one.YetiRevolution wrote:Just managed an 18:23 on column 00. Not a perfect run, since I had one small death on 08-1, and my movement wasn't great in a lot of places. Overall though I'm happy with it, and will probably take a break from column 00 even if someone beats me :p
edit: Eddy, you don't need to commentate, especially if you think it'll negatively affect your performance. Just make sure you record it ;)
If you don't feel like doing a live commentary, perhaps you can dub over a commentary over the top in post production. Perhaps talking about backup plans and what you were happy about/not so happy about etc.
- Semimember
Really? It seems like you've been here for ages! Hahaha... like... at least five years! Wow...YetiRevolution wrote:Thanks Ska, I'm not too worried about it :) Given that I've only really played the game for a year or two I'm happy with what I've achieved.
![Image](https://i.imgur.com/oa4KnIp.png)
