Also, this:
I do believe so ;) Also retook 23-2.macrohenry wrote:I wonder if it's possible to beat the drone.
Only 8 frames by beating the drone? I expected more out of you, Eddy.EddyMataGallos wrote:I do believe so ;) Also retook 23-2.macrohenry wrote:I wonder if it's possible to beat the drone.
jk, great run.
Nice job making use of that corner in the top left on both the way down and the way up. That was enough to make it happen. Nice work.EddyMataGallos wrote:I do believe so ;) Also retook 23-2.macrohenry wrote:I wonder if it's possible to beat the drone.
52 & 85 frames off the level 0th pace. That is pretty impressive. Nice job on 30-1 as well. That 0th route is damn hard. When Kool took that 0th I tried for hours to get two clean 8-tile jumps after the opening triple and failed miserably.macrohenry wrote:Ep20 and Ep30 taken. No idea why I suddenly went for episode speedruns.
Probably because Eddy isn't.macrohenry wrote:No idea why I suddenly went for episode speedruns.
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
2.5 Average Rank (3rd)
1 Episode Ownage b5 ![]()
Thanks Nyan!
Is 20-0 maxed anyways?
Nice Eddy. Those levels are all super tight.EddyMataGallos wrote:Tied 20-0, took 20-1, 20-2 and 20-3. Hmm, look at that, seems like I'm only missing the ep now...
Side note, would a low jump save frames on 20-1? I would think not since you already land almost before the door anyway, but it just popped in to my head.
In my humble opinion, those were a bit subpar for what macro could've pulled off in the speedrun of 2 relatively simple eps.TheRealOne wrote:52 & 85 frames off the level 0th pace. That is pretty impressive. Nice job on 30-1 as well. That 0th route is damn hard. When Kool took that 0th I tried for hours to get two clean 8-tile jumps after the opening triple and failed miserably.macrohenry wrote:Ep20 and Ep30 taken. No idea why I suddenly went for episode speedruns.
I've taken them and changed those figures to 4 & 7 frames off level 0th pace respectively. Improved my 0ths in 20-2, 20-4, 30-4; and took 30-3 on the way as well.
Cheers man. It could actually help, the reason we already land right before the door is because we jump before reaching the edge of the tile so as not to overshoot the door. A low jump would allow running to the end, but would this compensate the slight deceleration it causes?TheRealOne wrote:Nice Eddy. Those levels are all super tight.
Eddy is completely right. I guess I'm missing the patience to pull off a close to perfect episode run as those would take me at least 2 hours whereas Eddy most likely doesn't spend longer than 45 minutes on them. Impressive new 0ths, good job! Also, clever little innov in 30-1.EddyMataGallos wrote:In my humble opinion, those were a bit subpar for what macro could've pulled off in the speedrun of 2 relatively simple eps.TheRealOne wrote:52 & 85 frames off the level 0th pace. That is pretty impressive. Nice job on 30-1 as well. That 0th route is damn hard. When Kool took that 0th I tried for hours to get two clean 8-tile jumps after the opening triple and failed miserably.
Well if that is the case, what could the two of your narrow the SR EP Total to Level Total gap too?macrohenry wrote:Eddy is completely right. I guess I'm missing the patience to pull off a close to perfect episode run as those would take me at least 2 hours whereas Eddy most likely doesn't spend longer than 45 minutes on them. Impressive new 0ths, good job! Also, clever little innov in 30-1.EddyMataGallos wrote:In my humble opinion, those were a bit subpar for what macro could've pulled off in the speedrun of 2 relatively simple eps.TheRealOne wrote:52 & 85 frames off the level 0th pace. That is pretty impressive. Nice job on 30-1 as well. That 0th route is damn hard. When Kool took that 0th I tried for hours to get two clean 8-tile jumps after the opening triple and failed miserably.
Anyway, I just randomly took 16-0 with an obvious change at the end.
I notice you also took 16-4. There is a quicker ending to that level, where you jump onto the trampoline so that it throws you off at an angle to avoid the drone (see pic). I did manage it once, but died from hitting the roof with too much speed! :)EddyMataGallos wrote:Anyway, I just randomly took 16-0 with an obvious change at the end.
P.S. Also, you can beat the drone at the bottom if you skip the wall hug.
EDIT: Randomly took some 0ths in 26-1, 26-4, 51-1, 55-2, 56-4 and 75-2. 26-1 with naem's route again ^^
The sarcasm is palpable.EddyMataGallos wrote:But that super cool dude did beat the drone, although maybe you mean falling on the slope without wallsliding. Regarding that ending, well that's interesting, now it sounds familiar.
One frame off 75-2? Ugh. Well done on the route for 26-1 :)EddyMataGallos wrote:EDIT: Randomly took some 0ths in 26-1, 26-4, 51-1, 55-2, 56-4 and 75-2. 26-1 with naem's route again ^^
Well a frame lead is like a compliment for how clean your run was right? :P And thanks man._danielr_ wrote:One frame off 75-2? Ugh. Well done on the route for 26-1 :)
Took 15-0, 15-1 and 15-2.
Particularly happy with my -1, although it still includes some sloppiness at the top and at the end. The ending and the starting sequence is changed. I innovated the ending of -2 as well.
EDIT: Took 62-0 and 62-1. I wonder if I lost a frame at the end of -0.
Aha, I guess so. Thanks ;)EddyMataGallos wrote:Well a frame lead is like a compliment for how clean your run was right? :P_danielr_ wrote:One frame off 75-2? Ugh.
Taken -0 :)EddyMataGallos wrote:Took 62-0 and 62-1. I wonder if I lost a frame at the end of -0.
Cool innov, you gained that frame before the wj so it's possible that there's another frame left that we lost after the wj, maybe :P_danielr_ wrote:Taken -0 :)EddyMataGallos wrote:Took 62-0 and 62-1. I wonder if I lost a frame at the end of -0.
Took 11-1, 15-3, 63-1, 63-4, 64-0 and 64-1. Tied 15-4 and 63-2 as well. The first one seems cleanable, the second one could be maxed.
Nice runs. The extra WJ on the BB on 11-1 is awesome. Nice find.EddyMataGallos wrote:Cool innov, you gained that frame before the wj so it's possible that there's another frame left that we lost after the wj, maybe :P_danielr_ wrote:Taken -0 :)EddyMataGallos wrote:Took 62-0 and 62-1. I wonder if I lost a frame at the end of -0.
Well, credit to macro on that one then. That is a nifty little trick that looks like it save a nice chuck of frames.EddyMataGallos wrote:Much appreciated, I can't take credit for that though, that's macro's innov for hs (which has the same ending of course).
Notes: Used macro's hs route for 65-4, big innov in 66-3 and small ones in 64-3 and 65-3.
Users browsing this forum: Majestic-12 [Bot] and 20 guests
