Moderator: EddyMataGallos
Postby oxymoron93 » 2015.09.03 (18:10)
Well done sparta. I did give that level a go, like month ago. But I just couldn't get that thwump push... So I am 9th there now. I am satisfied with getting 19 on that route, which was max before coop unmaxed it. I will maybe try it, when I get of the board once...
85 sounds cool! More 15 to go. :D
[Edit] Ok, I couldn't give myself a peace over 48-4. The thing was limiting drone... I managed to beat it, tho it doesn't give you anything the way I did it. Beating he drone depends of previous gold stack collection. If it is done with as great speed as it is possible, and with some close shave pass near drone, it is possible to get to the launch pad before drone. Tho it will again be barely. And that has as a consequence that you need to use left direction and get more near to the wall (practically, to lean on it). So you actually lose horizontal speed, you need in top level. But, I have an idea I didn't execute (cause I am writing this after I managed to beat the drone for the first time). Here comes the picture:
http://imgur.com/uC6ws9C
Getting to the launch pad before drone with all gold collected, is one hell of a job! Just to warn everyone about that...
Postby shomman » 2015.09.04 (00:20)
Damn nice run oxy - you raped my score.
48-2 is amazing - such close encounters with the floorguards
gj sparta
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
2.5 Average Rank (3rd)
1 Episode Ownage b5 :):(
Other Stuff
Image Thanks Nyan!
Postby oxymoron93 » 2015.09.04 (00:36)
shomman wrote:48-2 is amazing - such close encounters with the floorguards
Unfortunately, I managed to do that top platform jump, even with shorter runway. So probably it is possible to do faster route... Even to collect three pieces of gold on left side... I will try it now. I have route in my mind. But I like my current 0th run... xD
[Edit] Much easier. Improved by 106 frames...
Postby shomman » 2015.09.04 (03:08)
Holy shit you monster. Oxy for Grandmaster!
improved on 48-4 but I couldn't get any higher. You win oxy :)
Edit: took 44-2 with a low jump, but only by a frame. Clearly lots of frames left to get but I hate that level. The key get is super annoying and the low jump is bloody hard.
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby oxymoron93 » 2015.09.05 (17:22)
Wow, beautiful run. I don't like the level especially because annoying exit key part... And that beginning, where you have to adjust your speed... Hate such levels. xD
Lets go on my side now. Taken b3-1 , a5-3 and 21-2.
I have something else to add to route on b3-1. It is hell of a change, but I won't do it now. It will take some time. Which I already lost cause of annoying a5-3. I just don't believe it took me so much time to beat Cineva by one frame...
I saw you played 21-2 and getting 84, I thought I should try it again, and to go full speed into exit door (in my previous, 86, run I slow down a little bit when I am in the air above drone, just before exit). And BOOOM I got 89! :D
I also played a6-1. I got the route too, but nothing else is changed. But I am sure you can get 49 with your route, cause I did it once, with missed gold in beginning...
Also 2 coop's levels are taken, that didn't happen a while. If we don't count spartax. xD
NUMA Profile: http://nmaps.net/user/SpartaX18
Postby SpartaX18 » 2015.09.05 (19:32)
Weeeee-haaaaaaw! Taken 00-2! I wonder if coop's gonna react (not only that i took his level, but also an entire ep ownage).
Postby shomman » 2015.09.06 (00:22)
Woah oxy, wrecking! Really impressive.
I took a5-2 back from oleary after a long long time.
gj sparta
Edit: oxy i see you testing parts of a5-2. Cheeky.
Edit 2: Also took a5-4, with a better jump up to the top that didn't require a walljump.
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby oxymoron93 » 2015.09.06 (07:47)
Wow, well done. I indeed hate that jump in a5-4. Tho, I had an idea before, how to avoid that way of climbing to the top.
[Edit] You can search on user levels for "181259", too see how Kind25 did it. It is faster, a little bit harder way, tho maybe I didn't practice it much. For the record I had 5025 with standard way. And that was pretty awesome, so ~15 frames can be added with Kind's way? You can also try your best with standard way on that level, to compare runs. But I said I had 25, and that was great score...
But, it was unexpected to see how tough the jump, I added in a5-4, actually is. Didn't do it once... xD
Postby shomman » 2015.09.06 (12:09)
Wow, Thanks. That's awesome. I considered that but it seemed really hard. I'll wait because I can't pull it off at the moment.
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby oxymoron93 » 2015.09.06 (15:02)
Improved b3-1 with idea I was talking about. Tho just 13 frames, with that nice change. I played much slower cause I didn't wan't to fuck up in the end... That gold can be collected faster, probably. You all can experiment now! xD
[Edit] Now run looks more decent! xD
Postby shomman » 2015.09.07 (10:00)
Damn Nice!!
My laptop has broken - so I won't be able to play N for a while, however long it takes to repair (might be months!)
Maybe I can get on PC at school to play but they are very slow :P
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby SpartaX18 » 2015.09.07 (17:19)
YUSS! Taken 01-0! coop is out of ep ownages right now!
Postby shomman » 2015.09.08 (02:58)
Wow, nice sparta. Just me alone now :)
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby SpartaX18 » 2015.09.08 (11:44)
Mwahahahaha...
Postby oxymoron93 » 2015.09.08 (13:05)
Yo, taken 23-1 , b0-4 (using same end as you did sho, still can't believe how is that faster) and b2-4 from Oleary (I pushed boundaries as much as it could before entering the last room, where any decent walljumper can do as I did).
Also aiming at 23-3 with slight change after grabbing exit key. It can be seen in my 49 run atm.
[Edit] Actually, it wasn't some work. I just have taken it, 2 mins after posting this. Can be done better! xD
Way to go Sparta. shomman is indeed the only one with episode ownage atm. And as long as i am concerned it can stay that way.
[Edit] After I played those levels in 23rd episode I noticed 22-2 and I wanted to try to get a better score now, when I am a little better walljumper.Cause after all, score you get depends of how soon you activate top thwump... So I tried a little bit, I could have got 702 maybe, nothing more. But I missed one piece... The thing is in one of my tries I managed to get awesome boost, which I do not know why, I thought to be impossible to do it in N2. I created test level, to test it, and it turned out to be possible. Search "181635". Some crazy stuff can be done with it on 22-2 probably... Tho, I do not know any person that crazy to try. xD
Also, where is this level in Nreality, so I can see how people over there did that thwump boost?
Postby SpartaX18 » 2015.09.08 (16:33)
OK, cooperverdon took 00-2 back :/ That's not too bad for me though... Okay, i spent like 2 hours on that level, but i don't care very much, because for me it's a casual 0th (maybe just the fact it's the third level in game makes it a bit more special). I wasn't aiming for (my first ever) episode ownage anyway; 00-4 is way too hard :P
Postby oxymoron93 » 2015.09.08 (22:03)
Change on 23-2 for another 0th in that episode. Again no special change, just avoiding hard part of previous route. I guess I am on 88 0ths now! xD
[Edit] Taken 19-2 today.
Postby SpartaX18 » 2015.09.09 (12:42)
Ugh, here comes the vengeance! coop took 01-0 back >.< The replay is corrupted though. I gotta look if he took anything else...
Also, damn it. oxy, you overpassed me once again! I didn't even notice when you took all those levels.
Postby oxymoron93 » 2015.09.09 (18:52)
Taken b0-3. I was tied with Cineva before. Probably previous way is maxed (you can check Cineva's run). I executed route with backward bounce block corner jump, after like hours of trying to do it(both on b0-3 itself and some user levels, I made, that refer to b0-3).
Honor to Oleary who first added bbbcj in b0-3!
[Edit] Well, PzylL has taken it. I can't believe how bbbcj's are easy for others to execute. xD
Postby shomman » 2015.09.10 (00:25)
Wow oxy, you're going hardcore. 181635 is madness, I didn't know that was possible either. Damn you taking b0-4 that level took so long :P
Sparta looks like you're being shows who the real boss is.
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby oxymoron93 » 2015.09.10 (22:02)
Retaken b0-3 from PzylL. I am going for my 90th 0th on b4-2. I have new route which I want to execute...
[Edit #1] Taken b4-2 with that new route. I had even better runs. 7k frames score is possible. Just to get better ending and that kkstrong-like grab of that piece of gold in top room.
Taken 24-2, too.
[Edit #2] WW didn't lose any 0th for long time till now. Taken 25-1 with a new route. Taken 29-3 also.
[Edit #3] Wow taken 28-1 with 3 big mistakes made during gold collection. But again perfect entering into bottom tunnel! That is what I call a luck! xD
Postby shomman » 2015.09.11 (05:43)
Jesus christ oxy. 25-1 is an amazing route. You're incredible. Oxy for Grandmaster
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby SpartaX18 » 2015.09.12 (17:19)
V
shomman wrote:Oxy for Grandmaster
No;
Edit: Credit to BtoasterBoy for the image.
Postby shomman » 2015.09.13 (05:52)
Took 23-4. Fluked a bit up near the end when I missed a landing.
Took 23-3. Nice ending oxy.
Took b2-4.Thought I was behind for most of the run, maybe that helped me by letting me go full speed at the end? I don't know but I took it by 3 frames.
Dammit nice oxy. I tied you but unlike usual I won't try and beat you :P. Too hard.
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
