Moderator: EddyMataGallos
85 sounds cool! More 15 to go. :D
[Edit] Ok, I couldn't give myself a peace over 48-4. The thing was limiting drone... I managed to beat it, tho it doesn't give you anything the way I did it. Beating he drone depends of previous gold stack collection. If it is done with as great speed as it is possible, and with some close shave pass near drone, it is possible to get to the launch pad before drone. Tho it will again be barely. And that has as a consequence that you need to use left direction and get more near to the wall (practically, to lean on it). So you actually lose horizontal speed, you need in top level. But, I have an idea I didn't execute (cause I am writing this after I managed to beat the drone for the first time). Here comes the picture:
http://imgur.com/uC6ws9C
Getting to the launch pad before drone with all gold collected, is one hell of a job! Just to warn everyone about that...
48-2 is amazing - such close encounters with the floorguards
gj sparta
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
2.5 Average Rank (3rd)
1 Episode Ownage b5
Thanks Nyan!
Unfortunately, I managed to do that top platform jump, even with shorter runway. So probably it is possible to do faster route... Even to collect three pieces of gold on left side... I will try it now. I have route in my mind. But I like my current 0th run... xDshomman wrote:48-2 is amazing - such close encounters with the floorguards
[Edit] Much easier. Improved by 106 frames...
improved on 48-4 but I couldn't get any higher. You win oxy :)
Edit: took 44-2 with a low jump, but only by a frame. Clearly lots of frames left to get but I hate that level. The key get is super annoying and the low jump is bloody hard.
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
1 Episode Ownage b5
Thanks Nyan!
Lets go on my side now. Taken b3-1 , a5-3 and 21-2.
I have something else to add to route on b3-1. It is hell of a change, but I won't do it now. It will take some time. Which I already lost cause of annoying a5-3. I just don't believe it took me so much time to beat Cineva by one frame...
I saw you played 21-2 and getting 84, I thought I should try it again, and to go full speed into exit door (in my previous, 86, run I slow down a little bit when I am in the air above drone, just before exit). And BOOOM I got 89! :D
I also played a6-1. I got the route too, but nothing else is changed. But I am sure you can get 49 with your route, cause I did it once, with missed gold in beginning...
Also 2 coop's levels are taken, that didn't happen a while. If we don't count spartax. xD
I took a5-2 back from oleary after a long long time.
gj sparta
Edit: oxy i see you testing parts of a5-2. Cheeky.
Edit 2: Also took a5-4, with a better jump up to the top that didn't require a walljump.
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
1 Episode Ownage b5
Thanks Nyan!
[Edit] You can search on user levels for "181259", too see how Kind25 did it. It is faster, a little bit harder way, tho maybe I didn't practice it much. For the record I had 5025 with standard way. And that was pretty awesome, so ~15 frames can be added with Kind's way? You can also try your best with standard way on that level, to compare runs. But I said I had 25, and that was great score...
But, it was unexpected to see how tough the jump, I added in a5-4, actually is. Didn't do it once... xD
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
1 Episode Ownage b5
Thanks Nyan!
My laptop has broken - so I won't be able to play N for a while, however long it takes to repair (might be months!)
Maybe I can get on PC at school to play but they are very slow :P
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
1 Episode Ownage b5
Thanks Nyan!
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
1 Episode Ownage b5
Thanks Nyan!
Also aiming at 23-3 with slight change after grabbing exit key. It can be seen in my 49 run atm.
[Edit] Actually, it wasn't some work. I just have taken it, 2 mins after posting this. Can be done better! xD
Way to go Sparta. shomman is indeed the only one with episode ownage atm. And as long as i am concerned it can stay that way.
[Edit] After I played those levels in 23rd episode I noticed 22-2 and I wanted to try to get a better score now, when I am a little better walljumper.Cause after all, score you get depends of how soon you activate top thwump... So I tried a little bit, I could have got 702 maybe, nothing more. But I missed one piece... The thing is in one of my tries I managed to get awesome boost, which I do not know why, I thought to be impossible to do it in N2. I created test level, to test it, and it turned out to be possible. Search "181635". Some crazy stuff can be done with it on 22-2 probably... Tho, I do not know any person that crazy to try. xD
Also, where is this level in Nreality, so I can see how people over there did that thwump boost?
Also, damn it. oxy, you overpassed me once again! I didn't even notice when you took all those levels.
Honor to Oleary who first added bbbcj in b0-3!
[Edit] Well, PzylL has taken it. I can't believe how bbbcj's are easy for others to execute. xD
Sparta looks like you're being shows who the real boss is.
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
1 Episode Ownage b5
Thanks Nyan!
[Edit #1] Taken b4-2 with that new route. I had even better runs. 7k frames score is possible. Just to get better ending and that kkstrong-like grab of that piece of gold in top room.
Taken 24-2, too.
[Edit #2] WW didn't lose any 0th for long time till now. Taken 25-1 with a new route. Taken 29-3 also.
[Edit #3] Wow taken 28-1 with 3 big mistakes made during gold collection. But again perfect entering into bottom tunnel! That is what I call a luck! xD
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
1 Episode Ownage b5
Thanks Nyan!
No;shomman wrote:Oxy for Grandmaster
Edit: Credit to BtoasterBoy for the image.
Took 23-3. Nice ending oxy.
Took b2-4.Thought I was behind for most of the run, maybe that helped me by letting me go full speed at the end? I don't know but I took it by 3 frames.
Dammit nice oxy. I tied you but unlike usual I won't try and beat you :P. Too hard.
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
1 Episode Ownage b5
Thanks Nyan!
