NReality recognizes demos but not levels - problem
this is the latest version and I'm using Vista. any help?
- Bacardi
Well I don't know why this happens, but it only seems to do so if the transparent update loads before you go into userlevels. If you want to prevent it, try to get into userlevels before the transparent update loads. (If the number in the box is 111791, then the levels should work, but if the number is 136604, they might not) Once you manage to get into userlevels before the transparent update loads, the levels should work fine. The levels will still work even after the transparent update loads, just as long as you don't exit out of userlevels. (say, to switch over from highscores mode to speedrun mode) If you need to do this, then you may have to close and reopen NReality after changing the modes.
Quotes (Click to open):
AKA Xsczo on n++, discord, and twitchIzzy and TRO - #n-highscores: <@Izzy> Where'd those frames come from? | <TRO> meta's ninja runs faster | <@Izzy> He stole TFK'S?!
Kablizzy: Click
TOO BAD!
