Post a Run!
80-1, 80-2 and 83-2, but 83-2 is highly improveable as I innovated a jump at the bottom (frame 550-600) and used it only 1 out of 2 possible times. (could've used it at the end, too)
And if you missed them: 71-2 and 97-3.
EDIT: Nice 39-4, dark ;D
Unreality's awesome mod
also 7th in 31-0
Nothing innovative about the run, but it's the only time I will ever hope to beat the likes of xaelar and Mr_Lim, so I am relishing the moment :)
- Bacardi
Took the 0th pretty easily with a slightly altered method at the beginning.
Edit: Also, 79-2 speedrun. Took 0th by 37 frames with a new route and innovation.
Kablizzy: Click
TOO BAD!
I took 5th on 12-0, 8th on 60-2, and 11th on 90-0. just can't nail lat's weird jump.
also I took 7th from behappy on 31-0. :P
- Bacardi
Kablizzy: Click
TOO BAD!
I had a faster 47-0. but missed the walljump during a lag burst.Meta Ing wrote:47-0 speedrun.
I beat your 79-2, and it's still improvable.
- Bacardi
I'll just go ahead and take that back, thank you. =)Izzy wrote:I beat your 79-2, and it's still improvable.
(I think it's still improvable by 3 or 4 frames...)
*Waits for kryX*
Kablizzy: Click
TOO BAD!
12-0, oops.Meta Ing wrote:I don't see one by you on 12-2, life.
also a few questions about highscores:
if you record two demos with the same frame count, which demo is kept? as in on 60-4, I pull off a corner jump in the start, and the frame count is the same as my submitted demo. there's no way to submit a demo with the same frame count, is there? also, for episode highscores, is it just levels 0-4, because the frame count seems too high.
- Bacardi
The first demo with that frame count is kept. And no, not that I know of.Life247 wrote:if you record two demos with the same frame count, which demo is kept? as in on 60-4, I pull off a corner jump in the start, and the frame count is the same as my submitted demo. there's no way to submit a demo with the same frame count, is there?
Yeah. Episode highscores are the combined total of the episode scores. Just remember that in speedrun mode, the faster your scores, the smaller the frame count.Life247 wrote:also, for episode highscores, is it just levels 0-4, because the frame count seems too high.
Kablizzy: Click
TOO BAD!
Yeah. Episode highscores are the combined total of the episode scores. Just remember that in speedrun mode, the faster your scores, the smaller the frame count.[/quote]Life247 wrote:also, for episode highscores, is it just levels 0-4, because the frame count seems too high.
and I just realized that you need to play the actual episode to get the episode score, not in highscores. duh.
30-4, 8th on speedrun.
episode 30, 3rd on speedrun.
Takenn with a little innovation.Izzy wrote:I just took 149-0 with a slightly sketchy run and an innovation.
Nice 30-0 Life, it's all about the cirle jumping (=
I'm actually not sure you're innovation is faster as my run still has some room for improvement.ToeFaceKiller wrote:Takenn with a little innovation.Izzy wrote:I just took 149-0 with a slightly sketchy run and an innovation.
Edit: After re-watching my run, it has at max 2 frames to improve so yeah, your innovation is faster.
sorry for the crappy video. level 41-1, I corner jump and the bounceblock doesn't move.
it's the strangest thing.
