Sorry to bother again, but
Commodus
Postby Rule » 2008.12.31 (14:39)
How do you submit highscores? I have got a personal best, but where to ctrl+click? I've tried it in the watch-replay box but it does not work. :(
Postby wedgie » 2008.12.31 (15:00)
If you are connected, and get a high score then your score should be submitted automatically. If you have been playing offline, or just happen to have a personal best that has not been submitted, then just hit the 'submit' button next to the personal best scores in the highscores section.
It sounds like you are in the userlevels section.
Bacardi
Postby Meta Ing » 2009.01.01 (04:26)
He could mean userlevel highscores (in NReality), wedgie.
In which case, when you beat a map, the score will appear next to the map name. ctrl + click that to submit your demo.
Quotes (Click to open):
Kablizzy: Click
TOO BAD!
Postby wedgie » 2009.01.02 (16:58)
Ah right. Good call!
Commodus
Postby Rule » 2009.01.04 (17:44)
Ok, but in userlevels it does not safe my demo's :(
Postby lolzers » 2009.01.04 (17:46)
to play the demos you press the key that says demo playback then when it loads up the main screen then hit p and it will play
Make this smaller? Blizzy do!
Sig by BE_nSPIRED(He Owns)
Nedeter Nation number 49!
Bacardi
Postby Meta Ing » 2009.01.04 (18:45)
Rule wrote:Ok, but in userlevels it does not safe my demo's :(
This may sound a bit obvious, but make sure you are logged in in the configure menu; otherwise your records won't be saved.
Kablizzy: Click
TOO BAD!
Commodus
Postby Rule » 2009.01.08 (13:06)
You rock! xD
How do you open the highscore section? I'm full of questions I know :)
Bacardi
Postby Meta Ing » 2009.01.08 (20:52)
If you mean in userlevels, they usually load once you've loaded the map through the map id box at the top, and once the thumbnail of the map has loaded.
Kablizzy: Click
TOO BAD!
Commodus
Postby Rule » 2009.01.09 (12:34)
I know that one, but I mean the highscore section that is shown in the attachement above.
MBTI Type: ESFJ
Postby jackass » 2009.01.09 (12:43)
Press Highscores in the main menu
[align=center]Image
Commodus
Postby Rule » 2009.01.10 (09:22)
Eh, how the **** Could Ipossibly miss that? xD
