Inertia field? (DS)
Other sigs
ø„¸¨"°º¤ø„¸¸„ø¤º°" ¨¸„ø¤º°"¨
¨"°º¤ø„¸RAMBO ¸„ø¤º°"¨
¸„ø¤º°"¨¸„ø¤º°"¨¨"°º ¤ø„¸¨"°
- Lords a-Leaping
- Semimember
Also, how is that incorrect? An object [at rest/in motion] will stay [at rest/in motion] unless acted on by an external force. The drone provides the outside force. I see no problem?
- Bacardi
?Exüberance wrote:Where is it called an inertia drone? It's called a Force Field Drone in XBox360 version at least is it not?
The thing BionicCryonic is talking about isn't a drone, it's a blue, stationary 'field'. (that looks kind of like water.)
Kablizzy: Click
TOO BAD!
Did DS get different enemies or something?
- Bacardi
Kablizzy: Click
TOO BAD!
- Semimember
The drone and field are completely different things. the field is an oblect that only slows you down when you're in it. The drone moves and pushes you away when you get too closeExüberance wrote:Where is it called an inertia drone? It's called a Force Field Drone in XBox360 version at least is it not?
