The (mis?)adventures of Bob.
Postby Luminaflare » 2009.04.20 (22:51)
Ok decided to try one of those forum drives where the comic goes where the forum goers tell it to things so lets start off.
This is bob. (He has arms you just can't see them right now)
Bob is in a room with a door.
Ok forum goers now what does Bob do?
Postby Snuggletummy » 2009.04.20 (22:58)
Bob needs to enter said door and prepare a meal. The meal will be a random, so look at it this way, if it's chicken, chicken a la king, if it's fish, fish a la king, if it's turkey, fish a la king. The random food will actually be Soylent Green, to which you need to fix a meal that look like shit, but in the end, use the vial you received from the cook that taught you to... cook. After the battle of the chefs, Professor Farnsworth will then examine the vial and tell you that it is just water, laced with LSD.
Postby Luminaflare » 2009.04.20 (23:01)
Snuggletummy wrote:Bob needs to enter said door and prepare a meal. The meal will be a random, so look at it this way, if it's chicken, chicken a la king, if it's fish, fish a la king, if it's turkey, fish a la king. The random food will actually be Soylent Green, to which you need to fix a meal that look like shit, but in the end, use the vial you received from the cook that taught you to... cook. After the battle of the chefs, Professor Farnsworth will then examine the vial and tell you that it is just water, laced with LSD.
I'm not quite that good with spriting yet.
Postby lord_day » 2009.04.20 (23:10)
Open the door and be prepared for danger from all sides.
Postby Luminaflare » 2009.04.20 (23:27)
lord_day wrote:Open the door and be prepared for danger from all sides.
' this means thought '
" this means speech "
Bob: 'It's locked.'
Also every 6 panels I'll post a put together of those 6 panels with a page number. I will also upload double size panels on request.
Postby PALEMOON » 2009.04.21 (00:40)
Bob, you should look to see if there's a doormat. maybe the key to the door is under it.
Postby Universezero » 2009.04.21 (01:20)
Try and get the wires from the light bulb circuiting. Get the two wire lengths and electrify the lock. This should make it open, assuming it isn't a mechanical lock. If it is mechanical, break the light bulb and use a shard to try and unlock it.
Postby lord_day » 2009.04.21 (07:36)
I disagree. Working in the dark will be near impossible.
Postby Tunco » 2009.04.21 (09:39)
Luminaflare wrote: Bob: 'It's locked.'
Bob break the door. Or get a chainsaw. Make your body strong enough to break the door if he is not strong enough.
Postby Luminaflare » 2009.04.21 (13:01)
PALEMOON wrote:Bob, you should look to see if there's a doormat. maybe the key to the door is under it.
Bob: 'There is a distinct lack of doormat.'
Universezero wrote:Try and get the wires from the light bulb circuiting. Get the two wire lengths and electrify the lock. This should make it open, assuming it isn't a mechanical lock. If it is mechanical, break the light bulb and use a shard to try and unlock it.
Bob: 'Can't reach the light.'
(By the way those lines beneath his feet are supposed to be movement lines)
Tunco123 wrote:Bob break the door. Or get a chainsaw. Make your body strong enough to break the door if he is not strong enough.
Bob(last panel): 'That works too.'
NUMA Profile: http://nmaps.net/user/Eternal_Boredom
Postby DoctorAperture » 2009.04.21 (14:25)
Bob should weild the lamp as a broadsword... Those use d10s, losta damage to compensate for an apparently low strength score.
random stuff
obligatory ad for my comic(s)
Awww, so cute!
Postby unoriginal name » 2009.04.21 (14:51)
Okay, now try UZ's idea.
Postby Luminaflare » 2009.04.21 (15:24)
gloomp wrote:Okay, now try UZ's idea.
Bob: 'There is no keyhole, it's evidently locked from the other side.'
aperture wrote:Bob should weild the lamp as a broadsword... Those use d10s, losta damage to compensate for an apparently low strength score.
Postby DoctorAperture » 2009.04.21 (16:07)
NOW OBLITERATE THE DOOR!!!!
:p
random stuff
Awww, so cute!
Postby Luminaflare » 2009.04.21 (16:22)
Quick character design question, should he have arms or should he just have floating hands?
Postby Tunco » 2009.04.21 (16:36)
Luminaflare wrote:Quick character design question, should he have arms or should he just have floating hands?
Normal arms would be nice, I had enough with floating hands at Wii-Mii's.
Postby Luminaflare » 2009.04.21 (16:55)
aperture wrote:NOW OBLITERATE THE DOOR!!!!
:p
Panel 4: Bob: "AAAAAAAAAAGGGGGGGGHHHHHHH!!!!!!"
Panel 6: Bob: "Where am I?"
Postby DoctorAperture » 2009.04.21 (17:01)
can bob use magic?
If not he should blindly run around for a minute or so
random stuff
Awww, so cute!
Postby Tunco » 2009.04.21 (17:05)
Luminaflare wrote: ImageImage
Bob runs in panic to find a exit, then he accidentally smacks his head to a wall when running.
aperture wrote:can bob use magic?
He needs to find a wand.
Postby Luminaflare » 2009.04.21 (17:22)
Bob: 'Oh look a pile of cloth.'
Postby Spawn of Yanni » 2009.04.21 (17:29)
Use the cloth as a blindfold, that should make it easier to run around blindly.
Postby Tunco » 2009.04.21 (18:04)
Spawn of Yanni wrote:Use the cloth as a blindfold, that should make it easier to run around blindly.
Well, he shouldn't be blinded, or else he could smack his head to somewhere. That would hurt.
Postby DoctorAperture » 2009.04.21 (22:08)
he should take the cloth and keep it as a whip like weapon, the he should proceed, now on his guard
random stuff
Awww, so cute!
NUMA Profile: http://nmaps.net/user/kamikaze3000
MBTI Type: ESTJ
Postby kamikaze3000 » 2009.04.22 (11:01)
Tie the cloth round his head like a ninja and continue his search
Postby Erik-Player » 2009.04.22 (12:54)
Look up. What do you see?
