Postby Unreality » 2009.04.25 (03:40)
sorry because of the land battleing system, I have removed the feature of auto submitting to speedrun scoreboard when you submit a highscore run
MBTI Type: ESTP
Postby kkstrong » 2009.04.25 (05:13)
Postby Nexx » 2009.04.25 (07:14)
Unreality wrote:sorry because of the land battleing system, I have removed the feature of auto submitting to speedrun scoreboard when you submit a highscore run
Land battling system? Wha?
Postby Unreality » 2009.04.25 (07:51)
here's a map showing how drone acts as a timer to trigger things by triggering area trigger
http://nmaps.net/164902
land battling system: http://n.infunity.com/land.php
Postby bhz » 2009.04.25 (17:57)
WHY
WHY
WHY
WHY
PLEASE re-implement this
<Izzy> Who are you?
<Meta> I'm meta?
( #n-highscores )
Postby Neil_Bryan » 2009.04.28 (03:29)
I have a request for NReality...
Can you please next time, don't make the ninja get more easily killed when falling? Even in low heights, it gets killed easily.
Names of Towns
Shortest: Y
Postby Unreality » 2009.04.28 (05:41)
Neil_Bryan wrote:I have a request for NReality...
It is the same as original N
I believe you have played some player-mod which the ninja attribute is being modified by the map author?
MBTI Type: ESTP
Postby kkstrong » 2009.04.28 (14:42)
yeah, the player mod could be several things.
Terminal_vel (terminal velocity, or somethin like that)
jump_grav, g, and I think there are a couple more. Check the n.Wikia page, or download Modmaster, a program I made for simplifying mmaking NReality mods.
Postby Izzy » 2009.04.28 (15:01)
Whywhywhywhywhy!?
That was one of the best features. ;_;;;-w
Postby TheRealOne » 2009.04.28 (16:03)
Whywhywhywhywhy!?
QFT
Postby Unreality » 2009.04.28 (17:11)
TheRealOne wrote:
Whywhywhywhywhy!?
QFT
Feature reimplemented :D it won't interfere land system so you won't claim speedrun land unintentionally
Postby Yoshimo » 2009.05.01 (20:59)
Can you make the tiledrones tile-placing a bit more streamlined?
As you can see, this cannot be executed well because the tile drones drop tiles later then they should.
Postby Unreality » 2009.05.02 (02:34)
BionicCryonic wrote:Can you make the tiledrones tile-placing a bit more streamlined?
unfortunately it can't be more steamline
maybe you can make the radius of the drone = 0, and _alpha = 0, then the player won't see it at all and won't able to touch it at all
Postby Yoshimo » 2009.05.02 (03:33)
The effect I'm going for is a moving/expanding gap, so making it like that would chop it up to an intense degree. Thanks for the feedback though. Bio is off to try something new.
Postby Cheez » 2009.05.03 (19:33)
Hey unreality, could you explain to me please how to do Triggers?
I had: rockydrone^^1,doorkey,doorkey
I'm confuzzled. :[
| last.fm | NUMA | RYM |
<@Izzy> van prefers it long.
Postby Exüberance » 2009.05.07 (17:28)
<_< Nreality thought I was speedhacking....
...I wasn't even playing highscore levels. I was testing my level in Ned (and it was running at normal (for Vista) speed) o.O Luckily, I saved it multiple times, as I always do (you get used to it when you play even slightly oldish games like Age of Empires 2 on Vista). How exactely does Nreality check for cheating? My framerate was normal (rapidly switching between 8 and 14 ms/frame) and I have no different background processes than I normally do (not that Flash can detect that anyways). Is there any way to go BACK to the game, or does it just stay like that until you close it?
Nmaps.netNmaps.net
Postby Unreality » 2009.05.08 (02:50)
Exüberance just restart your NReality.
It is just due to the fact that NReality is way too sensitive to any change of program running speed. Sometimes the cpu lagged a millisecond and NReality recorded that millisecond. And the lag accumulates as time goes by. When you opened NReality for quite some time, the lag accumulated to an extent that it thinks that you maybe speedhacking.
I'm sorry but NReality has to be that sensitive in order to block speedhacking in short levels
Postby Exüberance » 2009.05.08 (17:50)
Unreality wrote:Exüberance just restart your NReality.
Can't you make it reset it's speedhack checking if it's running at normal speed for a certain time, so it will only kick you if it slows down repeatedly or for a slightly longer time? It's usually okay (I was trying to beat MTI for a while and it never crashed (though come to think of it I might have been using normal N then), but if something like a virus scanner starts it can mess up what you're doing)
Nmaps.netNmaps.net
Postby Cheez » 2009.05.08 (22:51)
Could someone answer my question?
I found out it goes after the door code, but I'm still confused.
Postby Yoshimo » 2009.05.08 (22:58)
MyCheezKilledYours wrote:Could someone answer my question?
I've got no professional advice, but try studying this code:
Postby Exüberance » 2009.05.09 (04:11)
http://n.wikia.com/wiki/List_of_NReality_Mods
Nmaps.netNmaps.net
Postby Unreality » 2009.05.09 (10:57)
Exüberance wrote:Can't you make it reset it's speedhack checking if it's running at normal speed for a certain time, so it will only kick you if it slows down repeatedly or for a slightly longer time?
since I don't risk of leaving any possible weak point on the speedhack detection system, and plus I'm lazy and plus it's better to put my time on other NReality feature so I guess your request will be on pending status XD
Postby Cheez » 2009.05.09 (13:03)
Thanks, BioCryo. The code helped. Basically, you set a number to the startTrigger, and then when you get the doorkey, it activates all items with a startTrigger of 1, right?
exüber: Thanks for trying to help, but I already had that in a WordPad document. I was trying to say that I couldn't understand what it was explaining. :/
Postby golf » 2009.05.09 (19:40)
Unreality, I may have said something about this a long time ago (as in probably last year), but I don't remember if I did or if it never made it out of my mind. Is it possible to put the scrolling text in the top-left corner of NED like it does in Metanet's v1.4? I find that I miss the text that tells me that the level is loaded, and the demo is recording when I play a level in NReality's NED. I hope this makes enough sense.
Thanks
Postby Unreality » 2009.05.10 (03:14)
...? what scrolling text?
