- MBTI Type: ESTP
- Beyond a Perfect Math Score
Land battling system? Wha?Unreality wrote:sorry because of the land battleing system, I have removed the feature of auto submitting to speedrun scoreboard when you submit a highscore run
http://nmaps.net/164902
land battling system: http://n.infunity.com/land.php
WHYUnreality wrote:sorry because of the land battleing system, I have removed the feature of auto submitting to speedrun scoreboard when you submit a highscore run
WHY
WHY
WHY
PLEASE re-implement this
<Meta> I'm meta?
( #n-highscores )
Can you please next time, don't make the ninja get more easily killed when falling? Even in low heights, it gets killed easily.
Shortest: Y
It is the same as original NNeil_Bryan wrote:I have a request for NReality...
I believe you have played some player-mod which the ninja attribute is being modified by the map author?
- MBTI Type: ESTP
Terminal_vel (terminal velocity, or somethin like that)
jump_grav, g, and I think there are a couple more. Check the n.Wikia page, or download Modmaster, a program I made for simplifying mmaking NReality mods.
Whywhywhywhywhy!?Unreality wrote:sorry because of the land battleing system, I have removed the feature of auto submitting to speedrun scoreboard when you submit a highscore run
That was one of the best features. ;_;;;-w
QFTIzzy wrote:Whywhywhywhywhy!?Unreality wrote:sorry because of the land battleing system, I have removed the feature of auto submitting to speedrun scoreboard when you submit a highscore run
Feature reimplemented :D it won't interfere land system so you won't claim speedrun land unintentionallyTheRealOne wrote:QFTIzzy wrote:Whywhywhywhywhy!?Unreality wrote:sorry because of the land battleing system, I have removed the feature of auto submitting to speedrun scoreboard when you submit a highscore run
As you can see, this cannot be executed well because the tile drones drop tiles later then they should.
unfortunately it can't be more steamlineBionicCryonic wrote:Can you make the tiledrones tile-placing a bit more streamlined?
maybe you can make the radius of the drone = 0, and _alpha = 0, then the player won't see it at all and won't able to touch it at all
The effect I'm going for is a moving/expanding gap, so making it like that would chop it up to an intense degree. Thanks for the feedback though. Bio is off to try something new.Unreality wrote:unfortunately it can't be more steamlineBionicCryonic wrote:Can you make the tiledrones tile-placing a bit more streamlined?
- Oops Pow Surprise
I had: rockydrone^^1,doorkey,doorkey
I'm confuzzled. :[
...I wasn't even playing highscore levels. I was testing my level in Ned (and it was running at normal (for Vista) speed) o.O Luckily, I saved it multiple times, as I always do (you get used to it when you play even slightly oldish games like Age of Empires 2 on Vista). How exactely does Nreality check for cheating? My framerate was normal (rapidly switching between 8 and 14 ms/frame) and I have no different background processes than I normally do (not that Flash can detect that anyways). Is there any way to go BACK to the game, or does it just stay like that until you close it?
It is just due to the fact that NReality is way too sensitive to any change of program running speed. Sometimes the cpu lagged a millisecond and NReality recorded that millisecond. And the lag accumulates as time goes by. When you opened NReality for quite some time, the lag accumulated to an extent that it thinks that you maybe speedhacking.
I'm sorry but NReality has to be that sensitive in order to block speedhacking in short levels
Can't you make it reset it's speedhack checking if it's running at normal speed for a certain time, so it will only kick you if it slows down repeatedly or for a slightly longer time? It's usually okay (I was trying to beat MTI for a while and it never crashed (though come to think of it I might have been using normal N then), but if something like a virus scanner starts it can mess up what you're doing)Unreality wrote:Exüberance just restart your NReality.
- Oops Pow Surprise
I've got no professional advice, but try studying this code:MyCheezKilledYours wrote:Could someone answer my question?
I found out it goes after the door code, but I'm still confused.
http://n.wikia.com/wiki/List_of_NReality_ModsMyCheezKilledYours wrote:Could someone answer my question?
since I don't risk of leaving any possible weak point on the speedhack detection system, and plus I'm lazy and plus it's better to put my time on other NReality feature so I guess your request will be on pending status XDExüberance wrote:Can't you make it reset it's speedhack checking if it's running at normal speed for a certain time, so it will only kick you if it slows down repeatedly or for a slightly longer time?
- Oops Pow Surprise
exüber: Thanks for trying to help, but I already had that in a WordPad document. I was trying to say that I couldn't understand what it was explaining. :/
Thanks
