Post a Run!
EDIT: My bad on the double post.
976 top 20 speedruns, giving me 0th in level top 20 speedruns. :D
TRO, that run looks so sexy.
!!!!!!!!!!TheRealOne wrote:Edited an old map, added some new things then made a cool FBF run on it. I think it is worth a look.
Did you use N Demo Splice for that?
<Meta> I'm meta?
( #n-highscores )
In theory, what's the max top 20 speedrun count you can get? :)Izzy wrote:This isn't actually a run, but an assload of them.
Presumably it's just the same as the number of maps, so 1000 (200 episodes of 5 maps)...Unreality wrote:In theory, what's the max top 20 speedrun count you can get? :)Izzy wrote:This isn't actually a run, but an assload of them.
...which means Izzy needs only 24 more to have a top20 on every single level o.0
Awesome :D:D:D
Edit: Super hot run TRO.
Edit 2: TFK - you need to resubmit your 149-0 speedrun.
Unreality's awesome mod
Actually no. There are a few levels that are already maxed out, such as 59-0, 90-4, 170-0, 14-2, and 37-2. There are probably 3-4 others.cheesemonger wrote:Presumably it's just the same as the number of maps, so 1000 (200 episodes of 5 maps)...Unreality wrote:In theory, what's the max top 20 speedrun count you can get? :)Izzy wrote:This isn't actually a run, but an assload of them.
Awesome :D:D:D
Along with that, I still have to speedrun MTI, Bricklayer, 37-3, and Platformula. I may be missing others.
Taken, nice find. If my computer wasn't randomly being a laggy bitch right now I would certainly improve my run. I think the CPU noticed nreality was the only program running, so it decided to max itself out for 10 minutes just for kicks and giggles.darkshadow wrote:Although my 178-2 speedrun has plenty of room for improvement, I just think it looks so darn cool.
Edit: CPU's back to normal, run improved.
Nah, that was just plain old fbf. Its a pretty easy map to fbf actually, but I am thinking about making a few more stupidly hard maps and making fbf demos of those, like my mine jumper one. Those demos for those maps most likely will be using fbf, rerecording, and demo splicing.bhz wrote:!!!!!!!!!!TheRealOne wrote:Edited an old map, added some new things then made a cool FBF run on it. I think it is worth a look.
- RoboBarber
Improved by 0.4 : 145.075 :D
Beaten by Meta.
EDIT: I watched the demo in fbf and I missed a ton of jumps in the final chimney so that run could have been like 610 or less.
- Bacardi
Wow. That's the most amazing short demo, (fbf or not) I've seen in a while.TheRealOne wrote:Edited an old map, added some new things then made a cool FBF run on it. I think it is worth a look.
Anyways, 110-1 highscore. Took it back from dark by almost 4 seconds. (96.125)
Kablizzy: Click
TOO BAD!
EDIT: Very nice run, Meta.
2nd EDIT: Think I maxed out 170284
Taken 170284cheesemonger wrote:170282 speed and highscore
<Meta> I'm meta?
( #n-highscores )
Equalled, not taked. Oh, and Alieren's highscore on 170282 is cheated; I want my 0th back ;_;bhz wrote:Taken 170284cheesemonger wrote:170282 speed and highscore
I had actually made my demo basically just to motivate you to get 96 since I found it was easily possible and I was hoping you would do it.Meta Ing wrote:Anyways, 110-1 highscore. Took it back from dark by almost 4 seconds. (96.125)
- RoboBarber
I knew that beating crappitrash won't be hard for you. But 147.000, very nice run. ;)xaelar wrote:147 exactly :Deru_bahagon wrote:87-2, 0th by 2 frames. I'm waiting for a xaelar's run :D
Edit: Another frame better, now a whole 2 frames in the lead.
nice onegolfkid wrote:0th on 94-0, by a frame! And, I think there may be another frame or two able to be taken off :D I'm gonna keep trying for a while yet. :)
Users browsing this forum: No registered users and 48 guests
