Welcome to the Post an Innovation thread, where either you're too impatient to do that run yourself, or you enjoy watching others succeed (otherwise it would be in Post a Run or the 0ths thread).
Post your innovations here and Eddy/van/notIzzy will steal them and get a 0th with them.
- Bacardi
No I don't think so...claire wrote:I don't get it.
Can we tell you to make a map involving dancing bears and Chuck Norris as an uber boss?
... Or what?
He means, if you can see some way to get a quicker run on any level, but you aren't able to pull it off, describe what you are trying to do and someone will (at least try to) do it.
I'm pretty sure that's what he means anyway...
Kablizzy: Click
TOO BAD!
Meta_Ing, here's how I would route a no-switch-agd on "The Execution of the Clown." I can't for the life of me jump on the left between the mines, but you sure can!
jump down to the exit
jump between the 3-4 or 4-5 mines and land on the mouth
jump onto the 3 tile and reverse jump up to the nose
cornerjump up to the door above you and collect the gold
jump down to the mouth and onto the wall
finish by walljumping up to the exit switch and fall to complete
does that help? :)
PS: the picture messes up after collecting the gold, unless you can pull that off.
- Bacardi
Thanks though.
Kablizzy: Click
TOO BAD!
- Legacy Elite
you started in the middle of the level, so I'm confused.Hendor wrote:Thought about this one a while back. Don't know if it's possible or not. Worth putting it out there. On a second look, I really don't think it's possible.
- Semimember
"Tomorrow you will rule the world, but not today." -Miss Favro, my art teacher
- MBTI Type: ESFP
It's really hard, I got to the nose corner jump, but that's it, still nice route.
With all the in-between mine jumping i have seen lately.. why not!?
It's pretty easy why nobody has done it jet.ska wrote:here's a classic conundrum - jump between the mines on 37-3!
1) in-between mine jumps with mines laying on the ground are much much harder to do
2) it wouldn't be much faster
3) I don't like that level ;)
Look at my run at the beginning of the second chamber. Instead of holding the jump button, you can fall and go between the thwump and the wall. If done properly, it can cut off about 30-40 frames.
Unreality's awesome mod
- Bacardi
Well it's my method technically... kryX just nearly perfected it.darkshadow wrote:Anyone want to use kryx's method for 03-0 speedrun in highscore mode. It should be a 0th.
But yeah, I think it's worth a shot.
Kablizzy: Click
TOO BAD!
My run involves triple jumping on the bounceblock, walljumping on the next one, and hitting the corner. I've been able to make it to the switch without hitting the corner by getting a perfect triple jump and walljumping at the perfect height.
I've only done this twice and hit the floor at 270 frames (DAMN WALLSLIDES).
- MBTI Type: ESFJ
Check Again
Other sigs
ø„¸¨"°º¤ø„¸¸„ø¤º°" ¨¸„ø¤º°"¨
¨"°º¤ø„¸RAMBO ¸„ø¤º°"¨
¸„ø¤º°"¨¸„ø¤º°"¨¨"°º ¤ø„¸¨"°
right at the beggiing fall down corner bounce(?) onto the platform wall jump then wall jump off the thwump coming down the wall jump between the to bounce pads
I could show you but i dont have the level data for that level =/
Other sigs
It is possible to, after the two walljumps on the right, to corner jump and then walljump the tile directly to the exit.
I can't pull it off again for some reason.
