Metanet 0ths Thread
How many votes will this poll get?
1
0
No votes
2
0
No votes
3
0
No votes
4
0
No votes
5
1
13%
6
3
38%
7
1
13%
8
1
13%
9
0
No votes
10
0
No votes
11
0
No votes
12
1
13%
13
0
No votes
14
0
No votes
15
0
No votes
16
0
No votes
17
1
13%
18
0
No votes
19
0
No votes
20
0
No votes
Total votes: 8
Postby TheRealOne » 2014.03.17 (22:52)
alsojp27ace wrote: Well its looks like I might be proven wrong very soon, awesome innov macro
Retaken 68-4
Edit: Also took that 10-0, and I didn't really get a low jump (To be honest I'm not sure how to do a low jump).
If you could combine that and Eddy's trip I agree you could easily get .500
Try out my Simple Challenge for low jumps http://www.nmaps.net/187034 Basically, when running to the edge of a tile you push the opposite direction of running and jump at the same time on the last frame before running off the tile. That will give you the low jump. The real tick is learning how to get the height right by figuring out how long to hold jump as well as only hold the "wrong" direction for a single frame. The more frames you hold the wrong way, the slower your speed from the jump will be.
Edit: I should also mention that the low jump is a position specific trick. In the sense that you can't always do it on the edge of any tile by just holding the opposite direction and jump on the last frame of running on a tile. Sometimes the "footing" of the ninja is just wrong and that means you either need to just approach again and hope the footing is slightly different or you need to hold the opposite direction and slide for 1 or more extra frames. Usually it is faster to try and different approach rather than sliding.
Postby alsojp27ace » 2014.03.17 (23:13)
Ah awesome thanks for that map TRO.
I improved my run by another frame, but I found that you need to maintain quite a bit of speed to get enough height from the RCJ, so if you have to slow down for the LJ it might not be possible to do both. I might do some MBD testing tomorrow.
Edit: Is it actually possible to do a corner kick off the first block or do I just suck?
Postby EddyMataGallos » 2014.03.18 (00:15)
alsojp27ace wrote:If you could combine that and Eddy's trip I agree you could easily get .500
If you want my opinion, I'd say up to .650 at least is doable by cleaning the rcj and including the trip, maybe more.
alsojp27ace wrote:Edit: Is it actually possible to do a corner kick off the first block or do I just suck?
Back in 2012 when I took it I did try that possibility, but I didn't manage it. It might be though, but if it were to be possible, it would be on the first second row block, specially with this new route after the rcj, but even with the old one I believe it's doable.
Postby TheRealOne » 2014.03.18 (01:15)
Not possible. Raif and I tested that when he made his MBD. You can't collect all three gold and get a CK. The right most gold and the angle required for a CK are mutually exclusive.
Postby EddyMataGallos » 2014.03.18 (01:24)
I see, that's what I was expecting :P Still, after the rcj it's possible though, as you come from underneath and you actually take the conflictive piece of gold on the way up, so you can try it out there jp, if you are still interested.
Postby golf » 2014.03.18 (02:49)
ska wrote:Bizarre 10-0. I tried many different trajectories trying to execute a RCJ to get up a level like that, but JP made that look so effortless!
Bizarre is right. Only got 3 clean rcj's up there in half an hour, but the end result is in between jp and Eddy so I'm pretty satisfied with that. Strangely, I had just about as many time where I clipped the corner from having just barely too little height that kicked me all the way over the platform, as I did tries that left me grabbing the side of it. Really amazing innov.
Edit: I don't think Eddy ever actually claimed this level as his own here... must have gotten too distracted with the discussions of low jumps and ck's.
Postby ska » 2014.03.18 (05:33)
Let me reiterate, when I was trying this innov over the years, I did manage to either hit the side part and wall jump up, or slowly ascend over it, but slower than the original route. I'd still just assume it was impossible if it wasn't for the fact at least 4 people have just implemented it.
Edit: add me onto the list ;)
Postby alsojp27ace » 2014.03.18 (10:57)
Haha I was expecting macro to have taken 10-0 when I woke up this morning, but instead everyone else has.
I want to see this sort of activity on every innovation!
Postby ska » 2014.03.18 (13:02)
a bit off topic, but macrohenry's 10-2 0th never ceases to impress me.
Postby EddyMataGallos » 2014.03.18 (18:36)
Oh true. I have to say that, after almost a year playing v2.0 rather than v1.4, it felt so unnatural to do that rcj at first haha, just as if I hadn't been playing N at all, luckily I recovered the feelings later on. The innov is really clever indeed, specially in 10-0 considering its one of the simplest levels, I wasn't expecting to see any innov of this caliber. Hey macro & jp you could take a look at 59-0, maybe you find a new route there :P
Postby alsojp27ace » 2014.03.18 (20:33)
Yeah whenever I switch from 2.0 back to 1.4 it feels strange, but you get used to it quite quickly.
I see you've also taken my 68-4 Eddy, are we perhaps seeing a return to defend your TLS?
Postby macrohenry » 2014.03.18 (20:54)
Wow, amazing 10-0 action! I find it amusing how active the highscoring community can be if you only give it a little "push". Congrats on the 0th, Eddy. I don't think I'll be able to beat you, that rcj doesn't seem to like me. :/
Nice 68-4 as well, but don't think that I won't defend my episode ownage! Retook 68-4 with some more innovations, breaking the 160 mark, and also took Ep59.
No, Eddy, not 83-0... D:
Postby EddyMataGallos » 2014.03.18 (21:08)
alsojp27ace wrote:Yeah whenever I switch from 2.0 back to 1.4 it feels strange, but you get used to it quite quickly.
Thanks, I'm not sure if I'll return or if its just today that I feel like playing, you know, I just felt the gratifying sensation of taking a 0th again, and its addictive haha.
macrohenry wrote:Wow, amazing 10-0 action! I find it amusing how active the highscoring community can be if you only give it a little "push". Congrats on the 0th, Eddy. I don't think I'll be able to beat you, that rcj doesn't seem to like me. :/
Thanks macro, awesome 68-4 ;) I love how that level is evolving since lat had the 0th, as ska mentioned. Was Ep.59 was because of my suggestion? haha.
I also took your 83-0 btw :P
EDIT: Oh I see you noticed before I posted... then MWAHAHAHA
Postby macrohenry » 2014.03.18 (21:12)
EddyMataGallos wrote:Was Ep.59 was because of my suggestion? haha.
No, I did that some days ago. Awesome grammar skills too. :P
Postby james_S » 2014.03.18 (21:46)
cool o_O suddenly I see Raif and then Eru_bahagon online here as well. ehm.
Postby alsojp27ace » 2014.03.18 (23:25)
Awesome 68-4 macro, although there's still quite a lot of time to be saved in that top-right gold collection
Not that I plan on retaking it or anything (probably).
Has anyone been keeping track of the scores?
EddyMataGallos wrote:I just felt the gratifying sensation of taking a 0th again, and its addictive haha.
Good, good, we have him hooked :p
Postby TheRealOne » 2014.03.18 (23:27)
This, this, and more of this.
Postby EddyMataGallos » 2014.03.19 (00:12)
Whoops, I probably changed the sentence while I was writting it :P
Retook 68-4, by using jp's innov.
Btw yeah jp I've been keeping track of all these changes ;)
ED: Retook 35-4 as well with that cool macro innov. Also took 87-3. And that puts me ahead on TLS again muahaha.
NUMA Profile: http://nmaps.net/user/LouDog004
Postby LouDog004 » 2014.03.19 (04:22)
No surrender, eddy!
Postby ska » 2014.03.19 (05:39)
The beast has awoken!
What's amusing to me, is that when I was trying to improve my 10-0 score, I saw Eddy's 0th (and watched it, naturally), but was just so used to seeing Eddy in 0th position, that it didn't even occur to me that it was his first 0th in a long time. Perhaps even more amazing, is the sheer cleanliness of these new Eddy runs. I mean, they are tight, tight, tight! Every one as impressive as the last. I think we might just have a battle on our hands!
Postby Raif » 2014.03.19 (13:09)
You guys beat my MBD. How rude.
Postby macrohenry » 2014.03.19 (13:31)
Wow, .775, impressive! Good job, Raif!
Postby EddyMataGallos » 2014.03.19 (17:10)
LouDog004 wrote:No surrender, eddy!
ska wrote:The beast has awoken!
Damn, you guys certainly know how to encourage one to keep playing, thank you ;) Took 84-0 to increase my TLS lead by 8.5 secs more, this was my biggest chunk left. Oh btw, Happy b-day ska!
By the way Raif, that MBD is really clean. I believe there are some specific conditions for the rcj which can allow you for a powerful enough jump to corner-kick on the top block as well. It might be too hard to determine those conditions though. Plus I'm not sure if its possible with the low jump.
Postby TheRealOne » 2014.03.19 (21:48)
Raif wrote:You guys beat my MBD. How rude.
Nice Raif! glad to see you still got it.
Nice runs Eddy. You can right back in to the swing here. Great to see. As for the RCJ on 10-0 I do think that there is something special about the one in your run that makes it a bit different than the average RCJ. I think it is the same type of CJ as 13-0 and 51-0. For some reason these CJs seem to have extra power to them and I am not sure why. Maybe it is just my imagination, but I think there may be something that triggers the huge height from them.
Also for 84-0 I think for any future 0th hopefuls this should always be attempted because it has the potential to save a nice chunk of time with near 0 risk.
Postby EddyMataGallos » 2014.03.19 (22:28)
TheRealOne wrote:Nice runs Eddy. You can right back in to the swing here. Great to see. As for the RCJ on 10-0 I do think that there is something special about the one in your run that makes it a bit different than the average RCJ. I think it is the same type of CJ as 13-0 and 51-0. For some reason these CJs seem to have extra power to them and I am not sure why. Maybe it is just my imagination, but I think there may be something that triggers the huge height from them.
Thanks man. I also believe the approach to certain cj's can somehow trigger that extra power, the thing is that, since a cj is actually a bug, the ninja getting into the tile and then getting bumped off, its behaviour can, in some scarce cases, be that rare (because damn, 51-0 is rare, it doesn't quite follow our instinctive cj rules, that we would apply when approaching any cj, but rather we just know it works like so when you approach it that way, and then we just copy that exact approach again, to achieve the same results). Its a rare behaviour, although certainly not random or else the demos wouldn't always work haha. Which means we still have a lot to learn from N and its physics after 10 years, and that makes it quite unique :P
As for my 10-0 rcj in particular, I have to say the one in my 0th wasn't nearly the most powerful I got, and thats what I base my previous comment on, I got some which landed me on the end of the platform, I don't even know how haha, but that's why I think that a proper approach could give enough power to reach the corner and corner-kick there again, the problem is to find the actual pattern needed, or the principles of that rare behaviour. Anyway thats something that will never be applied realtime, probably, so it really is an MBD concern, or for the sake of knowledge.
As for the 84-0 final trick, I managed it once, and with a slow run I still got .975 (missing gold I mean), but at the end I didn't try to improve my 0th with it. I think its a pretty good idea, but the thing is that, you do risk going too much to the left, and instead of hitting the corner, hitting the side of the thwump. That could have two consequences, the soft one is, you would wallslide and lose time. The worst one, which is probably what would happen, is that since the thwump is going to the right, after hitting it you would be slightly propelled to the right as well, as we know thats how N v1.4 handles momentum, and you wouldn't reach the door and die :P This is just a huge speculation though as that has never happened to me. Nevertheless, no risk no gain.
