Post a Run!
Postby ska » 2015.05.03 (18:36)
I thought I expressed that point in my post. At any rate, it was just a crude approximation based not on any empirical evidence, but instead on my intuition.
Postby golf » 2015.05.03 (20:23)
ska wrote:I thought I expressed that point in my post. At any rate, it was just a crude approximation based not on any empirical evidence, but instead on my intuition.
Right, I think we both agree here. Shall we once again congratulate shomman on his nice run and leave it at that?
Postby shomman » 2015.05.03 (22:01)
golf wrote:
shomman wrote:Had a quick go at 134-0, thanks to you lifdoff, and got a score to my surprise. First ever metanet score on nreality lol. I would suppose that nreality levels aren't so competitive as the first 100 or so.
Congratulations, shomman, you even almost took 0th! Definitely something to be proud of. But, to be precise, that's not a Metanet score. Metanet scores are only for the levels that were made by Metanet and included in the official 1.4 release of the game, which is to say episodes 00-99. Please don't take this the wrong way saying that what you did wasn't as worthy of an accomplishment; I would say the overall 0th quality of runs on the blue_tetris/Legacy episodes (100-199) are close to the quality of Metanet 0ths by now so to come so close to a 0th is pretty good. The main difference is there hasn't been as much competition on those as in the Metanet levels, so the threshold to get into the top20 is much lower than on the Metanet levels.
Ahh ok thanks for clarifying. The confusion is that we still call the userlevel columns "Metanet Levels" in Nv2.
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
2.5 Average Rank (3rd)
1 Episode Ownage b5 :):(
Other Stuff
Image Thanks Nyan!
Postby golf » 2015.05.03 (22:50)
shomman wrote:Ahh ok thanks for clarifying. The confusion is that we still call the userlevel columns "Metanet Levels" in Nv2.
Technically, the entire 80s column is also userlevels, similar to the A and B columns in v2. But since they were packaged as part of the official release, they get bundled into the Metanet levels. Same thing happens with those bonus columns in v2. The real distinction is what is part of the 'official' set of levels, and what has been made by players after release, which is what we call userlevels. In the case of 1.4, there was a level editor (and NUMA) from earlier versions, and M&R included a column of levels that users had made in the expansion to 100 episodes in 1.4.
Postby shomman » 2015.05.03 (23:13)
Ahh ok fair enough.
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
NUMA Profile: http://nmaps.net/user/lifdoff
Postby lifdoff » 2015.05.11 (16:55)
8th (discounting hackers, crappi and L3X) on 66-4.
Getting close to my goal of 10 Top 20s. :P
Postby macrohenry » 2015.05.11 (17:21)
lifdoff wrote:8th (discounting hackers, crappi and L3X) on 66-4.
You did it! This map is definitely not an easy one to highscore. Well done. Too bad that you didn't beat L3X though. :P
Postby lifdoff » 2015.05.11 (18:19)
Actually, I find the longer and trickier levels easier to highscore, because you don't have to be frame perfect. That's why I'm currently also working on 59-4 and 87-1 and -2.
Postby golf » 2015.05.11 (21:00)
lifdoff wrote:Actually, I find the longer and trickier levels easier to highscore, because you don't have to be frame perfect. That's why I'm currently also working on 59-4 and 87-1 and -2.
Congrats on the top10. You should be able to make your goal without too much extra trouble :) I also found the long levels to be easier to highscore starting out also, because there's a lot more room for small errors that don't kill your position. I think its because a lot of people get frustrated with the length of the run, and so they don't take the time to actually finish a clean run throughout. Same reason that episode scores are easier to make a top20 on, in my opinion.
Postby _danielr_ » 2015.05.18 (10:20)
Back to the old ways on 61-0 sr :)
Postby golf » 2015.05.20 (21:56)
123419 hs, inspired by lifdoff on irc.
Postby lifdoff » 2015.05.29 (09:09)
15th on 84-4, and I only AGD-1'd it.
Why was that so easy? Easiest Top 20 I've ever taken.
EDIT: Improved to 9th, and AGD'd.
Postby ska » 2015.05.29 (14:19)
lifdoff wrote:15th on 84-4, and I only AGD-1'd it.
The simple answer is that many of the 80s levels have not been cleaned to the extraordinarily high standards that most of the Metanet-created levels have. 84-0 is a good example of this; specifically, when LAT took the 0th to be almost 9 seconds ahead of 1st a few years ago. You will probably also find that by and large, the 80s levels have the largest differences between 0th and 19th when compared to the other columns. Other prominent examples include: 85-3, 89-4, 87-1, 85-1, 84-3, 82-1 and 83-3.
Postby golf » 2015.05.29 (23:59)
Since improved, but here is probably the derpiest ending you've ever seen in a top-10 run... 69-3 everybody!
Postby lifdoff » 2015.06.01 (21:27)
I rarely post NUMA runs here, but I thought this deserved to be seen. Probably the sickest run I have ever recorded. Shame it's only an AGD-2, it would have been killer as an AGD.
Postby MiBeM » 2015.06.03 (19:38)
Fun thing I noticed today: my best runs on episodes 00-07 are all from my column runs, with no deaths between the levels. Even though I wasn't very good back in 2012, I'm surprised I've managed to improve on my 'proper' runs from that time, and thought this was interesting enough to share. (00 is still not a top-20 though)
a.k.a. MoleTrooper/Molenator
Speedruns and stuff
Postby EddyMataGallos » 2015.06.03 (20:02)
All my Column 00 ep speedruns are, too, including a 1st in both ep02 and ep05, and a 2nd in ep8 (at the time). 7 of them are Top10. I was kind of dissapointed by the sr ep quality after this, tbh. We're talking about col00, not col80 :S
Postby MiBeM » 2015.06.03 (20:40)
The sr episodes really aren't very optimized, not even the 0ths. It's saying something about their quality that I - by no means a god-tier player - have been able to consistently take every episode I've played in the last year and a half.
Speedruns and stuff
Postby _danielr_ » 2015.06.04 (14:08)
MiBeM wrote:The sr episodes really aren't very optimized, not even the 0ths. It's saying something about their quality that I - by no means a god-tier player - have been able to consistently take every episode I've played in the last year and a half.
As soon as I have the time I'll put a change to that ;)
Postby EddyMataGallos » 2015.06.05 (02:36)
Postby ska » 2015.06.05 (03:48)
As soon as I have the time, I'll pork your mum! ;)
Postby lifdoff » 2015.06.06 (09:13)
5th on 134-3. Probably not that useful, my slight route alteration because you have to break the flow quite a bit but I'll be damned if it doesn't look awesome.
EDIT: Also took the episode from xaelar, and got a Top 10 on every level.
Postby lifdoff » 2015.06.07 (10:57)
Sorry for double-posting, but I just took 134-3 from Eddy.
My first non-episode 0th!
Postby ska » 2015.06.07 (13:53)
lifdoff wrote:Sorry for double-posting, but I just took 134-3 from Eddy.
Nice innov! Too bad it's going to get destroyed by Eddy; there is plenty of time to be shaved off.
Postby lifdoff » 2015.06.07 (14:03)
Yeah I'm under no illusions of it lasting haha. Still feels good though!
