Post a Run!
Right, I think we both agree here. Shall we once again congratulate shomman on his nice run and leave it at that?ska wrote:I thought I expressed that point in my post. At any rate, it was just a crude approximation based not on any empirical evidence, but instead on my intuition.
Ahh ok thanks for clarifying. The confusion is that we still call the userlevel columns "Metanet Levels" in Nv2.golf wrote:Congratulations, shomman, you even almost took 0th! Definitely something to be proud of. But, to be precise, that's not a Metanet score. Metanet scores are only for the levels that were made by Metanet and included in the official 1.4 release of the game, which is to say episodes 00-99. Please don't take this the wrong way saying that what you did wasn't as worthy of an accomplishment; I would say the overall 0th quality of runs on the blue_tetris/Legacy episodes (100-199) are close to the quality of Metanet 0ths by now so to come so close to a 0th is pretty good. The main difference is there hasn't been as much competition on those as in the Metanet levels, so the threshold to get into the top20 is much lower than on the Metanet levels.shomman wrote:Had a quick go at 134-0, thanks to you lifdoff, and got a score to my surprise. First ever metanet score on nreality lol. I would suppose that nreality levels aren't so competitive as the first 100 or so.
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
2.5 Average Rank (3rd)
1 Episode Ownage b5
Thanks Nyan!
Technically, the entire 80s column is also userlevels, similar to the A and B columns in v2. But since they were packaged as part of the official release, they get bundled into the Metanet levels. Same thing happens with those bonus columns in v2. The real distinction is what is part of the 'official' set of levels, and what has been made by players after release, which is what we call userlevels. In the case of 1.4, there was a level editor (and NUMA) from earlier versions, and M&R included a column of levels that users had made in the expansion to 100 episodes in 1.4.shomman wrote:Ahh ok thanks for clarifying. The confusion is that we still call the userlevel columns "Metanet Levels" in Nv2.
Ahh ok fair enough.golf wrote:Technically, the entire 80s column is also userlevels, similar to the A and B columns in v2. But since they were packaged as part of the official release, they get bundled into the Metanet levels. Same thing happens with those bonus columns in v2. The real distinction is what is part of the 'official' set of levels, and what has been made by players after release, which is what we call userlevels. In the case of 1.4, there was a level editor (and NUMA) from earlier versions, and M&R included a column of levels that users had made in the expansion to 100 episodes in 1.4.shomman wrote:Ahh ok thanks for clarifying. The confusion is that we still call the userlevel columns "Metanet Levels" in Nv2.
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
1 Episode Ownage b5
Thanks Nyan!
You did it! This map is definitely not an easy one to highscore. Well done. Too bad that you didn't beat L3X though. :Plifdoff wrote:8th (discounting hackers, crappi and L3X) on 66-4.
Getting close to my goal of 10 Top 20s. :P
Congrats on the top10. You should be able to make your goal without too much extra trouble :) I also found the long levels to be easier to highscore starting out also, because there's a lot more room for small errors that don't kill your position. I think its because a lot of people get frustrated with the length of the run, and so they don't take the time to actually finish a clean run throughout. Same reason that episode scores are easier to make a top20 on, in my opinion.lifdoff wrote:Actually, I find the longer and trickier levels easier to highscore, because you don't have to be frame perfect. That's why I'm currently also working on 59-4 and 87-1 and -2.
Why was that so easy? Easiest Top 20 I've ever taken.
EDIT: Improved to 9th, and AGD'd.
The simple answer is that many of the 80s levels have not been cleaned to the extraordinarily high standards that most of the Metanet-created levels have. 84-0 is a good example of this; specifically, when LAT took the 0th to be almost 9 seconds ahead of 1st a few years ago. You will probably also find that by and large, the 80s levels have the largest differences between 0th and 19th when compared to the other columns. Other prominent examples include: 85-3, 89-4, 87-1, 85-1, 84-3, 82-1 and 83-3.lifdoff wrote:15th on 84-4, and I only AGD-1'd it.
As soon as I have the time I'll put a change to that ;)MiBeM wrote:The sr episodes really aren't very optimized, not even the 0ths. It's saying something about their quality that I - by no means a god-tier player - have been able to consistently take every episode I've played in the last year and a half.
As soon as I have the time I'll put a change to that ;)_danielr_ wrote:As soon as I have the time I'll put a change to that ;)MiBeM wrote:The sr episodes really aren't very optimized, not even the 0ths. It's saying something about their quality that I - by no means a god-tier player - have been able to consistently take every episode I've played in the last year and a half.
As soon as I have the time, I'll pork your mum! ;)EddyMataGallos wrote:As soon as I have the time I'll put a change to that ;)_danielr_ wrote:As soon as I have the time I'll put a change to that ;)MiBeM wrote:The sr episodes really aren't very optimized, not even the 0ths. It's saying something about their quality that I - by no means a god-tier player - have been able to consistently take every episode I've played in the last year and a half.
Nice innov! Too bad it's going to get destroyed by Eddy; there is plenty of time to be shaved off.lifdoff wrote:Sorry for double-posting, but I just took 134-3 from Eddy.
My first non-episode 0th!
