Corner Jumps
Postby Eiturlyf » 2008.12.12 (23:21)
Corners hate me ;___;
Postby Rikaninja » 2008.12.14 (00:19)
Eiturlyf wrote:Corners hate me ;___;
Hmmmm.... Welll I seem to be improving at it. Level no. 5177 and 148914 really turned corner jumps on in my life of success. ;)
Postby aids » 2008.12.14 (01:21)
Life247 wrote:
George wrote:
superjumninja wrote:How long will it take to master them? I'm not rushing, I don't care if it will take a whole year to master.
You'll have mastered corner kicks when you can beat this map in under 15 seconds.
hopefully this is fast enough. (fbf)
is there any way to submit a demo in N Reality without recording it in N Reality? how does the control-click work? sorry to sound so stupid. :(
Postby George » 2008.12.14 (02:12)
Life247 wrote:is there any way to submit a demo in N Reality without recording it in N Reality? how does the control-click work? sorry to sound so stupid. :(
Not that I know of. When you go to your userlevels, you can enter a map number to load in a map from NUMA. You click on the map and after completing the level, your personal best is saved. Control + Clicking that will submit that to Unreality's server.
Postby Rikaninja » 2008.12.14 (03:31)
And therefore I and everyone else will be able to see your demos on NReality! I think I heard xaelar telling Road_Rage about putting a particular demo on NReality. But I also don't know of any way to transfer demos to NReality.
Postby golf » 2008.12.14 (23:51)
Life247 wrote:
golfkid wrote:Life247: Yes that's fast enough, and a good start, now try to do it in under 15 seconds non-fbf'd.
what's the fastest?
I can't not-fbf a demo to save my life. it's become second nature for me.
507 frames is the fastest currently up on Nreality. Your demo there is a pretty good try, that last corner jump to the exit key I think is the hardest.
Postby Condog » 2008.12.15 (00:54)
Uh, one of the main points of Nreality is to stop people from cheating. If you could submit any demo to the server from an external source, then people would be able to submie fbf'd demos to the server. If you want to do fbf runs, then do it in underclock mode.
Ctrl+click submits the personal best that is saved when you complete a level in the userlevels section. Depending on what mode you are currently using - highscore, speedrun or underclock - it will submit it to one of the respective Nreality servers.
Also, check Nreality for a 431 frame run ;)
Postby aids » 2008.12.15 (02:38)
that's good. I need to practice real-time (rt) demos.
Condog wrote: If you want to do fbf runs, then do it in underclock mode.
how do you switch modes? I can't figure it out.
Condog wrote:Also, check Nreality for a 431 frame run ;)
I like your start. congrats.
Postby Condog » 2008.12.15 (02:51)
Go to configure, and in the top right area, just below the frame rate slider, are three buttons labelled highscore, speed run and configure. and thanks. :D
Postby aids » 2008.12.15 (03:03)
Condog wrote:Go to configure, and in the top right area, just below the frame rate slider, are three buttons labelled highscore, speed run and configure. and thanks. :D
thanks! but underclock doesn't work?
Postby Condog » 2008.12.15 (03:04)
for underclock, you drag the slider to the left, over clock is to the right
Postby aids » 2008.12.15 (03:45)
what slider?
Postby Rikaninja » 2008.12.15 (03:53)
Nice question, I am looking to learn how to use Underclock myself. My problem is that you can't click on Underclock and therefore I can't use Underclock ;(((((+
Postby Condog » 2008.12.15 (04:49)
Oh. You need to complete a certain number of columns to unlock it. I'm not sure noh many though.
Postby ToeFaceKiller » 2008.12.15 (06:17)
6 columns it is.
Intel 80486
Postby epigone » 2008.12.16 (01:09)
Rikaninja wrote:Do you like corner-jumping? Or when you see a map with a corner-jump ou turn away to have a look at a map in your ability?
If you are proud of any particular corner-jumps you have performed then post them here and discuss.
- {RAN} Rikaninja
Yes, they are quite fun.
The Best of Epigone
Postby Rikaninja » 2008.12.16 (07:48)
ToeFaceKiller wrote:6 columns it is.
Thanks dudes. Oh mannnn! I have beaten only 5 collumms ;{. Which one should I beat next. [90's, 40's or 70's) ? And I just figured out how to do a corner jump of a 5 tile on the ground. But I'm not consistent ;}
Postby ToeFaceKiller » 2008.12.16 (09:54)
40 and 70 are both pretty easy columns. I would say those over the 90's only because of 96-4. Grrr 96-4.
Postby Rikaninja » 2008.12.17 (09:47)
Actually I have beaten those collums already :) Oh well, I haven't gotten any better at corner jumping. Though now I can pull small ones of a lot easier now! Thanks TFC anyway :}
Bacardi
Postby Meta Ing » 2008.12.17 (15:31)
I like corner jumps. Most corner jumps are pretty easy for me, although I still struggle with some.
My favorite corner jump that I've done would probably have to be the half-tile corner jump on 149390 highscores. Half tile corner jumps are the hardest kind of corner jumps in my opinion.
Quotes (Click to open):
Kablizzy: Click
TOO BAD!
Postby Izzy » 2008.12.17 (18:55)
Rikaninja wrote:Actually I have beaten those collums already :) Oh well, I haven't gotten any better at corner jumping. Though now I can pull small ones of a lot easier now! Thanks TFC anyway :}
Uh, who is TFC?
Yeah, half-tile CJs have to be the hardest. Bounceblock CJs are easy compered to those.
Postby George » 2008.12.18 (00:36)
Uh, who is TFC?
I think we all know he made a typo there... u_u"
And also, it's impossible to actually jump off the corners of a bounce block. Frame by frame analysis shows that the ninja technically still jumps off the side.
Postby Izzy » 2008.12.18 (01:19)
George wrote:And also, it's impossible to actually jump off the corners of a bounce block. Frame by frame analysis shows that the ninja technically still jumps off the side.
Ah, ok. Many of us still refer to them as lookatthis bounceblock cornerjumps. Well I do, at least without lookatthis in it.
So that means that thwump cornerjumps are walljumps too, right?
Postby ToeFaceKiller » 2008.12.18 (01:31)
Yeah. It's just easier to call them bounceblock or thwump corner jumps rather than bounceblock/thwump fast wall jump crazy things ya know?
Postby behappyy » 2008.12.18 (02:30)
Their fun but also really frustrating.
Image]THANK IZZ'
