Post a Run!
Yup, I got .8 doing that jump with a missed gold.
138944 taken (i have that faster route from nmaps, dunno why nobody did it without fbf) - slow ending (reaaaally slow)Tunco123 wrote:2 frames behind you! Oh, can't beat kryX, btw.cheesemonger wrote:168648
Speedrun and Highscore.
Oh, what a run.
Anyway;
Speed on ;
-138944
-152230
-2226
152230 taken, maybe it's max, i died at 103
2226 too
also 170-4 speed, my first 0th from kryX :P it can be much faster because of my crappy ending
and xaelar nice 16-3
- Oops Pow Surprise
I actually think the fastest route on 16-3 is to extend the jump on the second from the left platform to reach the exit platform then jump to the exit switch and jump back to the exit from there.
1 2 3
_________________
1 -> 2 -> 3 -> 2
I just don't know if that's possible without missing either the gold on the right of the second from the left platform or one of the golds on the jump from the leftmost one to it. (Yay for confusing descriptions!)
Edit: Why the crap do the spaces disappear in my horrid ascii drawing? What it's supposed to show is going 2nd->3rd->5th->3rd counting from the left side.
Edit 2: Possible 96-4 beginning?
Edit3: Is it just me or is the end of xaelar's descent on 90-3 significantly faster than kryX's?
1 2 3
_________________
1 -> 2 -> 3 -> 2
Unreality's awesome mod
I think they are very close if not the exact same speed until the last 1 tile there kryx holds right longer so he falls on the slant of the 1 tile, where as xela goes faster on the last 1 tile and he hits the corner of e tile and 1 tile on the floor, but I can't tell you which one is faster because i don't have the demo data for kryx's run to check with fbf.darkshadow wrote: Edit3: Is it just me or is the end of xaelar's descent on 90-3 significantly faster than kryX's?
169020
169026
Both speedruns.
169026
Both speedruns.
I was referring to specifically the last tile not the entire descent. I think that effect might allow a significantly faster fbf/underclock run.TheRealOne wrote:I think they are very close if not the exact same speed until the last 1 tile there kryx holds right longer so he falls on the slant of the 1 tile, where as xela goes faster on the last 1 tile and he hits the corner of e tile and 1 tile on the floor, but I can't tell you which one is faster because i don't have the demo data for kryx's run to check with fbf.darkshadow wrote: Edit3: Is it just me or is the end of xaelar's descent on 90-3 significantly faster than kryX's?
Yeah, I think you are right. I post this a while back and Knu got .650 (374 frames) and he nicks the corner like xela, but he also does the last jump of the chimney differently so I can't how much faster it is to hit that corner, but it faster.darkshadow wrote:I was referring to specifically the last tile not the entire descent. I think that effect might allow a significantly faster fbf/underclock run.TheRealOne wrote:I think they are very close if not the exact same speed until the last 1 tile there kryx holds right longer so he falls on the slant of the 1 tile, where as xela goes faster on the last 1 tile and he hits the corner of e tile and 1 tile on the floor, but I can't tell you which one is faster because i don't have the demo data for kryx's run to check with fbf.darkshadow wrote: Edit3: Is it just me or is the end of xaelar's descent on 90-3 significantly faster than kryX's?
I had completely forgotten that Knu did 90-3. That fact that he used that same trick convinces me that it's faster since, given how much time Knu put into perfecting his fbf runs, I can't imagine him using a slower method.TheRealOne wrote:Yeah, I think you are right. I post this a while back and Knu got .650 (374 frames) and he nicks the corner like xela, but he also does the last jump of the chimney differently so I can't how much faster it is to hit that corner, but it faster.darkshadow wrote: I was referring to specifically the last tile not the entire descent. I think that effect might allow a significantly faster fbf/underclock run.
I bet you could easily get a highscore on 90-3 TRO. You should go for it.
I have tried. I really want one. I got a 147.825 with a missed gold once, but I absolutely suck at the double perp jump at the begining going in to the chimney, it messes with the rhythm of my chimney.ToeFaceKiller wrote:I bet you could easily get a highscore on 90-3 TRO. You should go for it.
- Oops Pow Surprise
Tied kryX and 999_Springs on that.cheesemonger wrote:168648
Might be able to tie you...
Interestingly macrohenry uses a completely different route on 54-2 that's still faster than the old one. Also, what the hell is with the the central bounceblock on 56-4? I've had a run over two seconds faster than the 0th ruined because of it's weird instability.
I don't know what you are talking about with the center bounce block, but I can say that, that maps needs some work, xaelar's run seems quite sloppy for a xaelar 0th.darkshadow wrote:what the hell is with the the central bounceblock on 56-4? I've had a run over two seconds faster than the 0th ruined because of it's weird instability.
Weird, I've noticed that before too, it's almost as if that bounceblock is lighter than normal. More bounce than block!darkshadow wrote:Also, what the hell is with the the central bounceblock on 56-4? I've had a run over two seconds faster than the 0th ruined because of it's weird instability.
30-1 speedrun innovation
If I didnt royal fuck the end, it would have been a a lot faster than the current 0th.
I think that was rabarint's old route before the scoreboard mess up.TheRealOne wrote:30-1 speedrun innovation
Nice innovation. It's definitely faster. FBF demo
Road_rage
138552 highscore.
134005 highscore.
Haha, that's ridiculous. I made a demo on that map a longg time ago but never submitted till now. Me and a kid were taking shifts on it, heh.
definitely wasting server space to store those demo :|
980 highscore (164.550(Beaten kryX by 0.150))
Users browsing this forum: No registered users and 38 guests
